This is the result of my not updating the png widget to use the latest
library. You may find sources for the older version at
http://ics-web.sns.ornl.gov/edm/docs/show.php?folderId=4.
On 2/18/15, 8:47 AM, "Mike Westfall" <[email protected]> wrote:
>For Ubuntu, I'm guessing you need to do
> > sudo apt-get install libpng-dev
>On 02/18/2015 01:15 AM, Rahul Jain wrote:
>> Hello,
>> I am facing problem in installing edm-1-12-98, although I have already
>> installed the following libraries required for EDM installation on my
>> linux-x86 (ubuntu 14.04) PC.
>> libx11-dev, libxtst-dev, zlib1g-dev giflib-4.1.3, libungif-4.1.3,
>> libpng-1.2.6rc1-config, libxt-dev, libmotif-dev, x11proto-print-dev,
>> libxmu-headers, libxp-dev, libxmu-dev, libxmu6
>> The error messages, while installing edm-1-12-98 is given as follows:-
>> /usr/bin/g++ -o edm -L/opt/myepics/base-3.14.12.4/lib/linux-x86
>> -L/opt/myepics/extensions/lib/linux-x86 -L/usr/lib
>> -L/usr/lib/i386-linux-gnu
>> -Wl,-rpath,/opt/myepics/base-3.14.12.4/lib/linux-x86
>> -Wl,-rpath,/opt/myepics/extensions/lib/linux-x86 -Wl,-rpath,/usr/lib
>> -Wl,-rpath,/usr/lib/i386-linux-gnu -m32 -z combreloc -z lazyload
>> main.o -lcfcaa62e-8199-11d3-a77f-00104b8742df
>> -l114135a4-6f6c-11d3-95bc-00104b8742df -lXm -lXmu -lXt -lXp -lXtst -lX11
>> -lca -lCom -lpthread -ldl
>> /usr/bin/ld: warning: -z lazyload ignored.
>> /usr/lib/libXm.so: undefined reference to `png_read_info@PNG12_0'
>> /usr/lib/i386-linux-gnu/libfreetype.so.6: undefined reference to
>> `png_set_filler@PNG12_0'
>> `png_set_packing@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_set_sig_bytes@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_read_update_info@PNG12_0'
>> `png_set_interlace_handling@PNG12_0'
>>`png_create_read_struct@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_get_rowbytes@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_read_image@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_set_gray_to_rgb@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_get_IHDR@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_get_channels@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_set_strip_16@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_set_expand@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_init_io@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_get_gAMA@PNG12_0'
>> `png_get_io_ptr@PNG12_0'
>> `png_set_palette_to_rgb@PNG12_0'
>> `png_get_error_ptr@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_set_gamma@PNG12_0'
>> `png_destroy_read_struct@PNG12_0' /usr/lib/libXm.so: undefined reference
>> to `png_read_end@PNG12_0'
>> `png_error@PNG12_0'
>> `png_set_read_user_transform_fn@PNG12_0'
>> `png_set_read_fn@PNG12_0'
>>`png_create_info_struct@PNG12_0'
>> `png_set_expand_gray_1_2_4_to_8@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_sig_cmp@PNG12_0'
>> /usr/lib/libXm.so: undefined reference to `png_get_valid@PNG12_0'
>> `png_set_tRNS_to_alpha@PNG12_0'
>> collect2: error: ld returned 1 exit status
>> make[2]: *** [edm] Error 1
>> make[2]: Leaving directory
>> `/opt/myepics/extensions/src/edm/edmMain/O.linux-x86'
>> make[1]: *** [install.linux-x86] Error 2
>> make[1]: Leaving directory `/opt/myepics/extensions/src/edm/edmMain'
>>make:
>> *** [edmMain.install] Error 2
>> Please suggest me, how to fix this error message.
>> Regards
>> Rahul Jain
>Mike Westfall
>Gemini Observatory
>Colina El Pino S/N, Casilla 603
>La Serena, Chile
>Tel: +56 51 2205625
- Re: Error in EDM-1-12-98 installation Rahul Jain
- Error in EDM-1-12-98 installation Rahul Jain
- Re: Error in EDM-1-12-98 installation Mike Westfall
CSS - Reverse Scale Amien Crombie
<2015>
2025
<2015>
2025
