Hello all,
I have already installed the suggested packages on my PC.
libpng12-0 (suggested y Mr. Mark Rivers)
libpng-dev (suggested by Mr. Mike Westfall)
libpng-1.2.6rc1-config (suggested by Mr. Sinclair, John William)
In my /usr/bin directory following files are present
libpng-config & libpng12-config
and in /usr/include directory following files are present
png.h & pngconf.h
When I had not installed the package libpng-1.2.6rc1-config suggested by
Mr. Sinclair, John William, I was getting following error message.
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux
-D_REENTRANT -O3 -g -Wall -DSINGLE_THREADED=1 -D__epics__=1 -m32
-fPIC -MMD -I. -I../O.Common -I. -I..
-I../../../../include/edm/os/Linux -I../../../../include/edm
-I../../../../../base/include/os/Linux -I../../../../../base/include
-I../../../../include -I../../util -I../../lib -I/usr/include
-I/usr/include/X11 ../png.cc
In file included from ../png.cc:21:0:
../myPng.h:25:17: fatal error: png.h: No such file or directory
#include "png.h"
compilation terminated.
make[2]: *** [png.o] Error 1
make[2]: Leaving directory
`/opt/myepics/extensions/src/edm/pnglib/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/opt/myepics/extensions/src/edm/pnglib'
make: *** [pnglib.install] Error 2
After flashing this error message, I already downloaded and installed the
libpng-1.2.6rc1-config from the same link
http://ics-web.sns.ornl.gov/edm/docs/show.php?folderId=4 suggested by Mr.
Sinclair, John William now and I used following steps to install this
package:-
cd Downloads
tar -zxvf libpng-1.2.6rc1-config.tar.gz
cd libpng-1.2.6rc1-config
./configure --prefix=/usr
make check
make
sudo make install
Further, I again tried to install the EDM, but I was getting the same
error message which I posted in the beginning of this mail. Please guide
me in this regard.
Rahul Jain
RRCAT, Indore (INDIA)
> ---------------------------- Original Message ----------------------------
> Subject: Re: Error in EDM-1-12-98 installation
> From: "Sinclair, John William" <[email protected]>
> Date: Wed, February 18, 2015 8:10 pm
> To: "Mike Westfall" <[email protected]>
> "Rahul Jain" <[email protected]>
> "[email protected]" <[email protected]>
> This is the result of my not updating the png widget to use the latest
> library. You may find sources for the older version at
> http://ics-web.sns.ornl.gov/edm/docs/show.php?folderId=4.
> On 2/18/15, 8:47 AM, "Mike Westfall" <[email protected]> wrote:
>>For Ubuntu, I'm guessing you need to do
>> > sudo apt-get install libpng-dev
>>On 02/18/2015 01:15 AM, Rahul Jain wrote:
>>> Hello,
>>> I am facing problem in installing edm-1-12-98, although I have already
>>> installed the following libraries required for EDM installation on my
>>> linux-x86 (ubuntu 14.04) PC.
>>> libx11-dev, libxtst-dev, zlib1g-dev giflib-4.1.3, libungif-4.1.3,
>>> libpng-1.2.6rc1-config, libxt-dev, libmotif-dev, x11proto-print-dev,
>>> libxmu-headers, libxp-dev, libxmu-dev, libxmu6
>>> The error messages, while installing edm-1-12-98 is given as follows:-
>>> /usr/bin/g++ -o edm -L/opt/myepics/base-3.14.12.4/lib/linux-x86
>>> -L/opt/myepics/extensions/lib/linux-x86 -L/usr/lib
>>> -L/usr/lib/i386-linux-gnu
>>> -Wl,-rpath,/opt/myepics/base-3.14.12.4/lib/linux-x86
>>> -Wl,-rpath,/opt/myepics/extensions/lib/linux-x86 -Wl,-rpath,/usr/lib
>>> -Wl,-rpath,/usr/lib/i386-linux-gnu -m32 -z combreloc -z lazyload
>>> main.o -lcfcaa62e-8199-11d3-a77f-00104b8742df
>>> -l114135a4-6f6c-11d3-95bc-00104b8742df -lXm -lXmu -lXt -lXp -lXtst
>>> -lX11
>>> -lca -lCom -lpthread -ldl
>>> /usr/bin/ld: warning: -z lazyload ignored.
>>> /usr/lib/libXm.so: undefined reference to `png_read_info@PNG12_0'
>>> /usr/lib/i386-linux-gnu/libfreetype.so.6: undefined reference to
>>> `png_set_filler@PNG12_0'
>>> `png_set_packing@PNG12_0'
>>> /usr/lib/libXm.so: undefined reference to `png_set_sig_bytes@PNG12_0'
>>> `png_read_update_info@PNG12_0'
>>> `png_set_interlace_handling@PNG12_0'
>>>`png_create_read_struct@PNG12_0'
>>> /usr/lib/libXm.so: undefined reference to `png_get_rowbytes@PNG12_0'
>>> /usr/lib/libXm.so: undefined reference to `png_read_image@PNG12_0'
>>> /usr/lib/libXm.so: undefined reference to `png_set_gray_to_rgb@PNG12_0'
>>> /usr/lib/libXm.so: undefined reference to `png_get_IHDR@PNG12_0'
>>> /usr/lib/libXm.so: undefined reference to `png_get_channels@PNG12_0'
>>> /usr/lib/libXm.so: undefined reference to `png_set_strip_16@PNG12_0'
>>> /usr/lib/libXm.so: undefined reference to `png_set_expand@PNG12_0'
>>> /usr/lib/libXm.so: undefined reference to `png_init_io@PNG12_0'
>>> /usr/lib/libXm.so: undefined reference to `png_get_gAMA@PNG12_0'
>>> `png_get_io_ptr@PNG12_0'
>>> `png_set_palette_to_rgb@PNG12_0'
>>> `png_get_error_ptr@PNG12_0'
>>> /usr/lib/libXm.so: undefined reference to `png_set_gamma@PNG12_0'
>>> `png_destroy_read_struct@PNG12_0' /usr/lib/libXm.so: undefined
>>> reference
>>> to `png_read_end@PNG12_0'
>>> `png_error@PNG12_0'
>>> `png_set_read_user_transform_fn@PNG12_0'
>>> `png_set_read_fn@PNG12_0'
>>>`png_create_info_struct@PNG12_0'
>>> `png_set_expand_gray_1_2_4_to_8@PNG12_0'
>>> /usr/lib/libXm.so: undefined reference to `png_sig_cmp@PNG12_0'
>>> /usr/lib/libXm.so: undefined reference to `png_get_valid@PNG12_0'
>>> `png_set_tRNS_to_alpha@PNG12_0'
>>> collect2: error: ld returned 1 exit status
>>> make[2]: *** [edm] Error 1
>>> `/opt/myepics/extensions/src/edm/edmMain/O.linux-x86'
>>> make[1]: Leaving directory `/opt/myepics/extensions/src/edm/edmMain'
>>>make:
>>> *** [edmMain.install] Error 2
>>> Please suggest me, how to fix this error message.
>>> Regards
>>> Rahul Jain
>>Mike Westfall
>>Gemini Observatory
>>Colina El Pino S/N, Casilla 603
>>La Serena, Chile
>>Tel: +56 51 2205625
- Error in EDM-1-12-98 installation Rahul Jain
- Re: Error in EDM-1-12-98 installation Mike Westfall
- Re: Error in EDM-1-12-98 installation Sinclair, John William
Re: CSS - Reverse Scale Amien Crombie
RE: Using the EPICS Build/Make system to build kernel modules for linux Williams Jr., Ernest L.
<2015>
<2015>
