Hi Techtalk,
I'm currently working on writing an areadetector module for some Nikon cameras (http://www.nikon.com/products/instruments/lineup/bioscience/camera_microscopy/dsqi2/index.htm) The problem I am currently having (I think) has something to due with me configuring one of the makefiles in this module incorrectly. I went through file by file (comparing to other areadetector modules which compile totally fine on my machine) to make sure my module adheres to the other examples. I am using release 2.1 of areadetector (both core and binaries). I can compile many other AD modules fine, including a custom areadetector module I built last year for varian detectors. The problem is my **Support.dbd file does not seem to get properly copied into iocs/**IOC/**App/src/O.Common (where ** is my app name- "Ks") . I can temporarily fix the problem by copying the **Support.dbd file into O.Common but then I get other build errors (No rule to make target **.lib needed by **App.exe. This is fixed (for some reason) by me commenting out PROD_LIBS in my ioc src makefile. and THEN I get LNK2001 error about unresolved external symbol pvar_func_KsRegister ) I am hoping these errors are all related. Here is my terminal output: make -C ./configure install make[1]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/configure' perl C:/base-3.14.12.4/bin/windows-x64/makeMakefile.pl O.windows-x64 ../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../.. T_A=windows-x64 install make[2]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/configure/O.windows-x64' perl C:/base-3.14.12.4/bin/windows-x64/convertRelease.pl checkRelease make[2]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/configure/O.windows-x64' make[1]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/configure' make -C ./KsApp install make[1]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp' make -C ./src install make[2]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/src' perl C:/base-3.14.12.4/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../../.. T_A=windows-x64 install make[3]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/src/O.windows-x64' cl /nologo /EHsc /GR -c /favor:blend /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\base-3.14.12.4\\include -IC:\\support\\asyn-4-26\\include -IC:\\support\\areaDetector-R2-0\\ADBinaries\\include\\os\\WIN32 -IC:\\support\\areaDetector-R2-0\\ADBinaries\\include -IC:\\support\\areaDetector-R2-0\\ADCore\\include\\os\\WIN32 -IC:\\support\\areaDetector-R2-0\\ADCore\\include ..\\Ks.cpp Ks.cpp ..\Ks.cpp(435) : warning C4101: 'pstInfo' : unreferenced local variable lib /nologo /verbose /out:Ks.lib /LTCG Ks.obj Appending Ks.obj "Installing library ../../../lib/windows-x64/Ks.lib" make[3]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/src/O.windows-x64' make[2]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/src' make -C ./Db install make[2]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/Db' perl C:/base-3.14.12.4/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../../.. T_A=windows-x64 install make[3]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/Db/O.windows-x64' make[3]: Nothing to be done for 'install'. make[3]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/Db/O.windows-x64' make[2]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/Db' make[1]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp' make -C ./iocs install make[1]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs' make -C ./KsIOC install make[2]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC' make -C ./configure install make[3]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/configure' perl C:/base-3.14.12.4/bin/windows-x64/makeMakefile.pl O.windows-x64 ../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../.. T_A=windows-x64 install make[4]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/configure/O.windows-x64' perl C:/base-3.14.12.4/bin/windows-x64/convertRelease.pl checkRelease make[4]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/configure/O.windows-x64' make[3]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/configure' make -C ./KsApp install make[3]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/KsApp' make -C ./src install make[4]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/KsApp/src' perl C:/base-3.14.12.4/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../../.. T_A=windows-x64 install make[5]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/KsApp/src/O.windows-x64' perl C:/base-3.14.12.4/bin/windows-x64/makeIncludeDbd.pl KsSupport.dbd commonDriverSupport.dbd KsAppInclude.dbd echo "../O.Common/KsAppInclude.dbd : ../Makefile" >> KsApp.dbd.d "Expanding dbd" Can't open include file "KsSupport.dbd" Error at or before ""KsSupport.dbd"" in file "../O.Common/KsAppInclude.dbd" line 1 dbExpand: Input errors, no output generated C:/base-3.14.12.4/configure/RULES.Db:261: recipe for target '../O.Common/KsApp.dbd' failed make[5]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/KsApp/src/O.windows-x64' C:/base-3.14.12.4/configure/RULES_ARCHS:63: recipe for target 'install.windows-x64' failed make[4]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/KsApp/src' C:/base-3.14.12.4/configure/RULES_DIRS:70: recipe for target 'src.install' failed make[3]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/KsApp' C:/base-3.14.12.4/configure/RULES_DIRS:70: recipe for target 'KsApp.install' failed make[2]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC' C:/base-3.14.12.4/configure/RULES_DIRS:70: recipe for target 'KsIOC.install' failed make[1]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs' C:/base-3.14.12.4/configure/RULES_DIRS:70: recipe for target 'iocs.install' failed My Makefile inside the KsApp/src/ folder: ################################################# TOP=../.. include $(TOP)/configure/CONFIG #---------------------------------------- # ADD MACRO DEFINITIONS AFTER THIS LINE LIBRARY_IOC += Ks LIB_SRCS += Ks.cpp DBD += KsSupport.dbd include $(ADCORE)/ADApp/commonLibraryMakefile #============================= include $(TOP)/configure/RULES #---------------------------------------- # ADD RULES AFTER THIS LINE #################################################### My Makefile inside the iocs\KsIOC\KsApp\src folder: #################################################### TOP=../.. include $(TOP)/configure/CONFIG #---------------------------------------- # ADD MACRO DEFINITIONS AFTER THIS LINE PROD_NAME = KsApp PROD_IOC += $(PROD_NAME) # <name>.dbd will be created from <name>Include.dbd DBD += $(PROD_NAME).dbd $(PROD_NAME)_DBD += KsSupport.dbd # <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd PROD_SRCS += $(PROD_NAME)_registerRecordDeviceDriver.cpp $(PROD_NAME)Main.cpp # Add locally compiled object code PROD_LIBS += Ks include $(ADCORE)/ADApp/commonDriverMakefile #============================= include $(TOP)/configure/RULES #---------------------------------------- # ADD RULES AFTER THIS LINE #################################################### Any help would be greatly appreciated. Thanks, Andrew
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
