In order to make my head clean from the project management, I am doing
to write an IOC for the Keithley 6514 electrometer currently. ECR Ion
source team has a Faraday cup, they want to use that Keithley model to
record the extracted beam current with the remote or serial connection.
I've found some already developed Keithley IOCs from EPICS sites, and
google-found-sites, and learned how other people uses it within the
EPICS framework. They are excellent to glimpse a functionality before I
start to work on it.
The developed IOC works fine with a simple and basic functionality.
This unit has two ways to setup the integration time of the A/D
converter. The first way is to use a selected value between 0.01 and 10.
The second one is to use the predefined values, such as SLOW, MED, and
FAST. The end user wants to use only the predefined values (SLOW, MED,
and FAST).
--- DB file ---
record(mbbo, "$(SYS)-$(SUBSYS):$(DEV):SetADRate")
field(DESC, "Set Predefined Rate")
field(DTYP, "stream")
field( OUT, "@devkeithley6514.proto setADRate $(PORT) $(A)")
field(ZRST, "Slow")
field(ZRVL, "0")
field(ONST, "Med")
field(ONVL, "1")
field(TWST, "Fast")
field(TWVL, "2")
field(FLNK, "$(SYS)-$(SUBSYS):$(DEV):GetADRate")
record(mbbi, "$(SYS)-$(SUBSYS):$(DEV):GetADRate")
field(DESC, "Get Predefined Rate")
field( INP, "@devkeithley6514.proto getADRate $(PORT) $(A)")
field(ZRST, "Slow")
field(ZRVL, "0")
field(ONST, "Med")
field(ONVL, "1")
field(TWST, "Fast")
field(TWVL, "2")
field(PINI, "YES")
--- protocol file ---
setADRate {
out "CURR:NPLC %{6.00|1.00|0.10}";
@init { out "CURR:NPLC?"; in "%{6.00|1.00|0.10}"; }
getADRate {
ExtraInput = Ignore;
It works fine if I set only predefined bit in mbbo and mbbi, such as
0, 1, and 2.
case 1) caput ECR11-Diag:FC01:SetADRate 3
returns the following messages:
Warning: enum index value '3' may be too large.
Old : ECR11-Diag:FC01:SetADRate Slow
CA.Client.Exception...............................................
Warning: "Channel write request failed"
Context: "op=1, channel=ECR11-Diag:FC01:SetADRate, type=DBR_DOUBLE,
count=1, ctx="ECR11-Diag:FC01:SetADRate""
Source File: ../oldChannelNotify.cpp line 160
New : ECR11-Diag:FC01:SetADRate
Current Time: Wed Mar 04 2015 07:56:12.932662247
At this point, the following 4 values are
ECR11-Diag:FC01:SetADRate.VAL
ECR11-Diag:FC01:SetADRate.RVAL 0
ECR11-Diag:FC01:SetADRate.STAT CALC
ECR11-Diag:FC01:SetADRate.SEVR INVALID
case 2) caput ECR11-Diag:FC01:SetADRate -1
New : ECR11-Diag:FC01:SetADRate Illegal Value
Current Time: Wed Mar 04 2015 07:56:05.867136097
ECR11-Diag:FC01:SetADRate.VAL Illegal Value
ECR11-Diag:FC01:SetADRate.STAT SOFT
Two behaviors are quite acceptable and reasonable in terms of a
client, but the many problems are in the IOC itself. IOC prints a ton of
error or warning messages as follows
Case 1)
2015/03/04 14:07:30.017055 cbLow Value 3 not found in enum set
2015/03/04 14:07:30.017583 cbLow ECR11-Diag:FC01:SetADRate: Formatting
value 3 failed
2015/03/04 14:07:30.017610 cbLow ECR11-Diag:FC01:SetADRate: Cannot
format value with '%{6.00|1.00|0.10}'
Case 2)
2015/03/04 14:07:12.854089 cbLow Value 65534 not found in enum set
2015/03/04 14:07:12.854104 cbLow ECR11-Diag:FC01:SetADRate: Formatting
value 65534 failed
2015/03/04 14:07:12.854283 cbLow ECR11-Diag:FC01:SetADRate: Cannot
Here is my question:
How to ignore out-of-range index in mbbo or mbbi in both cases?
Where I have to implement it?
Han
Jeong Han Lee, Dr.rer.nat.
Accelerator Systems Division
Rare Isotope Science Project
Institute for Basic Science
Daejeon, South Korea
tel : +82-42-878-8733
fax : +82-42-878-8799
- Re: How to handle out-of-index of MBBO/MBBI? Michael Davidsaver
Re: "No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
Re: error on the IOC shell for asyn driver Vishnu Patel
<2015>
RE: error on the IOC shell for asyn driver Mark Rivers
<2015>
