Hi:
On Mar 19, 2015, at 4:30 AM, Kalyani Thigale/TVM/TCS <[email protected]>
wrote:
> I am unable to start archive engine application. Following is the log file.
> Please provide solution.
Are you trying to start an archive engine binary that you downloaded from somewhere, or are you trying to build it yourself from sources?
>From the log I assume that you're doing the latter because of the "..runtime-ArchiveEngine.." workspace that's usually set by the IDE.
Then the problem could be that you're using older sources (archive.engine_3.3.0 is from Feb. 2014, requiring a 3.7.2 IDE, Java 7), yet a newer IDE.
For a current setup (Eclipse 4.4.2, Java 8) you better use the current sources. See http://cs-studio.sourceforge.net/docbook chapter on Compiling, Running, Debugging CSS.
Or start by using a binary, see if you get that to run, and then go into building one yourself. See https://ics-web.sns.ornl.gov/css/updates/apps/?C=M;O=D
Thanks and Regards,
Kay
> !SESSION 2015-03-19 13:58:50.415 -----------------------------------------------
> eclipse.buildId=unknown
> java.version=1.8.0_25
> java.vendor=Oracle Corporation
> BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_GB
> Framework arguments: -product org.csstudio.archive.engine.engine -engine Demo -port 5432
> Command-line arguments: -product org.csstudio.archive.engine.engine -data /home/847016/Workspaces/../runtime-ArchiveEngine.product -dev file:/home/847016/Workspaces/.metadata/.plugins/org.eclipse.pde.core/ArchiveEngine.product/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog -engine Demo -port 5432
> !ENTRY org.eclipse.osgi 4 0 2015-03-19 13:59:16.374
> !MESSAGE Application error
> !STACK 1
> org.eclipse.core.runtime.CoreException: Plug-in org.csstudio.archive.engine was unable to load class org.csstudio.archive.engine.Application.
> at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
> at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:178)
> at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
> at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
> at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:191)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:483)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
> Caused by: java.lang.NoClassDefFoundError: org/eclipse/equinox/app/IApplication
> at java.lang.ClassLoader.defineClass1(Native Method)
> at java.lang.ClassLoader.defineClass(ClassLoader.java:760)
> at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:272)
> at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:632)
> at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:588)
> at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540)
> at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527)
> at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
> at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320)
> at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:395)
> at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)
> at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)
> at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
> at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:568)
> at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
> ... 16 more
> Caused by: java.lang.ClassNotFoundException: org.eclipse.equinox.app.IApplication cannot be found by org.csstudio.archive.engine_3.3.0.qualifier
> at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:432)
> ... 32 more
> Thanks and Regards,
> Kalyani Thigale
> Notice: The information contained in this e-mail
> message and/or attachments to it may contain
> confidential or privileged information. If you are
> not the intended recipient, any dissemination, use,
> review, distribution, printing or copying of the
> information contained in this e-mail message
> and/or attachments to it are strictly prohibited. If
> you have received this communication in error,
> please notify us by reply e-mail or telephone and
> immediately and permanently delete the message
> and any attachments. Thank you
- Error while staring archive engine in eclipse Kalyani Thigale/TVM/TCS
Re: pyepics not updating pv.enum_strs after connection Matt Newville
Re: EDM -ctl opens new window instead of raising old one John William Sinclair
<2015>
2025
areaDetector to control Pilatus GONG Yu
<2015>
2025
