On Wed, May 13 2015, Michael Davidsaver <[email protected]> wrote: > On 05/13/2015 01:06 PM, Jameson Graef Rollins wrote: >> On Tue, May 12 2015, Michael Davidsaver <[email protected]> wrote: >>> ... >> Hi, Michael. I should have mentioned that I did try doing this at your >> suggestion, but wasn't able to devine anything useful myself. I'm not >> quite sure what I'm looking for, though: > > The error is coming from: > > http://bazaar.launchpad.net/~epics-core/epics-base/3.14/view/head:/src/libCom/osi/os/posix/osdMutex.c#L108 > > If the unlock fails then cantProceed() is called, which calls > epicsThreadSuspendSelf. The posix version of which ultimately calls > pthread_cond_wait(). > > http://bazaar.launchpad.net/~epics-core/epics-base/3.14/view/head:/src/libCom/osi/os/posix/osdEvent.c#L75 Thanks Michael! This sounds somewhat promising. > From the top two frames this could be either thread #1 or #4. Can you > post the full stacks? This program utilizes two processes: a "main" daemon process and a "worker" sub-process. The daemon holds the PCAS, while the worker uses pyepics to do the work. Attached is the gdb bt output for the threads of both the "MAIN" and the "WORKER" for one of these wedged nodes. Like I said, I'm pretty sure the problem is in the PCAS, so I think the problem is in the MAIN, but I include the WORKER bt for completeness. I don't actually have a wedged node right now, so I can't get any more info until it happens again. If there's some other gdb info I can retrieve next time this happens, please do let me know. jamie. Attachment:
epicsMutex_pthread_error-SEI_HAM6 Attachment:
signature.asc
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
