Hi All,
I have a scalcout record whose output should go into a bo record, as follows: record(scalcout, "BS:CAMS_OK") { field(SCAN, ".1 second") field(CALC, "AA==CC") field(INAA, "CAM1:TRAFFIC_LIGHT") field(OUT, "BS:AUTO PP") field(OOPT, "When Zero") field(CC, "OK") } record(bo, "BS:AUTO") { field(PINI, "YES") field(VAL, "0") field(ZNAM, "OFF") field(ONAM, "ON") } When I run the IOC, I get this error message: Illegal choice PV: BS:AUTO 0.00000000 After looking at other posts, I think the scalcout is trying to write a string in the bo, which generates the error. But my understanding of the scalcout documentation is that the conversion to int should be done automatically, and this should just work. Interestingly, this workaround does the job: record(scalcout, "BS:CAMS_OK") { field(CALC, "AA==CC") field(INAA, "CAM1:TRAFFIC_LIGHT") field(CC, "OK") } record(calcout, "BS:CAMS_OK_FAN") { field(SCAN, ".1 second") field(INPA, "BS:CAMS_OK PP") field(OUT, "BS:AUTO PP") field(OOPT, "When Zero") } record(bo, "BS:AUTO") { field(PINI, "YES") field(VAL, "0") field(ZNAM, "OFF") field(ONAM, "ON") } So it looks like if a record "pulls" the result from scalcout it's OK, but scalcout doesn't "push" it correctly. I could live with the workaround, but it's a bit of a hack...
Any thoughts on why this is not working? Cheers, Isabella
- RE: scalcout fails to write to bo Mooney, Tim M.
Re: A issue when trying to use modbus module Mark Rivers
<2015>
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
