1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS base-3.14.12.5 installation error
To: Alex George <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 22 Jun 2015 14:24:03 -0500
On 06/22/2015 12:28 PM, Alex George wrote:
>   cd C:/epics/base-3.14.12.5/src/softIoc
>   icacls ../../bin/windows-x64/registerRecordDeviceDriver.pl
> C:\epics\base-3.14.12.5\src\softIoc>icacls ../../bin/windows-x64/registerRecordDeviceDriver.pl
> ../../bin/windows-x64/registerRecordDeviceDriver.pl BUILTIN\Administrators:(I)(F)
>                                                     NT AUTHORITY\SYSTEM:(I)(F)
>                                                     BUILTIN\Users:(I)(RX)
>                                                     NT AUTHORITY\Authenticated Users:(I)(M)
> Successfully processed 1 files; Failed processing
None of the names listed there are obviously your user account, so I'm
becoming more convinced that this problem is due to file permissions.
When I run the same command for my build the result looks like this:
> D:\epics\mirror-3.14\src\softIoc>icacls ..\..\bin\windows-x64\registerRecordDeviceDriver.pl
> ..\..\bin\windows-x64\registerRecordDeviceDriver.pl ANL\anj:(I)(F)
>                                                     ANL\Domain Users:(I)(RX)
>                                                     Everyone:(I)(RX)
> Successfully processed 1 files; Failed processing 0 files
I'm logged in as ANL\anj and I have full permissions (F) over that file.
Can any Windows experts out there comment on this? I don't really
understand the intricacies of the Windows permissions system or how
ActiveState Perl may be unable to execute a script which it itself
installed earlier in the build process.
Alex,
If you can either take ownership or give yourself full permissions over
the C:/epics directory tree (and all its subdirectories and files) that
will probably fix the problem. You would do that by bringing up Windows
Explorer and the Properties dialog for the directory, then go to the
Security tab and click the Edit button.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
RE: EPICS base-3.14.12.5 installation error freddie.akeroyd
EPICS base-3.14.12.5 installation error Alex George
Re: EPICS base-3.14.12.5 installation error Johnson, Andrew N.
Re: EPICS base-3.14.12.5 installation error Andrew Johnson
Re: EPICS base-3.14.12.5 installation error Alex George
Prev: Re: EPICS base-3.14.12.5 installation error Alex George
Next: multi-channel analog i/p Stephen Paul
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: EPICS base-3.14.12.5 installation error freddie.akeroyd
