1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about device support
To: Ralph Lange <[email protected]>
Date: Fri, 26 Jun 2015 15:46:13 +0200
Hey all,
so far I have my device support working, and
changing output-records, when the value on the
hardware was changed, works also.
Only one last problem:
Switching the device on/off is done via a bo record.
If the state of this switch was changed outside of EPICS,
the device support changes the RVAL field of the bo record to 0 (or 1
respectively),
but VAL ( "Off" | "On" ) does not change.
Device support routine returns with 0 after changing RVAL.
How can I get the device support/record to update also the VAL field?
Cheers,
Florian
On 05/26/2015 03:52 PM, Florian Feldbauer wrote:
> Hey Ralph,
> yes, I experienced such a problem for my current device support
> for our iseg HV modules.
> There I'm also using the asynPortDriver (one driver per module).
> For "small scale" systems (about one crate) it works,
> but with larger setups we also have problems with the port-locking...
> For the new device support I'm currently working on, this is no issue,
> since now I don't have any hardware i/o at all.
> iseg is providing their so called Hardware Abstraction Layer which works
> as a daemon collecting and caching all the parameters of the
> connected HV modules.
> The device support just communicates with the daemon to get the cached
> values or queue new values to be send by the daemon, respectively.
> But looking at your first reply to this topic, programming a thread
> checking if any set-values have changed and updating the corresponding
> output-records seems not too hard. So maybe I will try to write
> the device support myself and keep the asynPortDriver as backup solution.
> Cheers
> Florian
> On 05/26/2015 02:46 PM, Ralph Lange wrote:
>> Hi Florian,
>> Yet another thing to keep in mind is the level at which you want locking
>> of things to happen.
>> Usually (in the blocking case), a port driver locks its port, does the
>> IO, then unlocks its port.
>> Some years ago at BESSY we were thinking how our CAN-Bus driver would
>> fit the ASYN model. CANopen compliant, i.e. many nodes per bus (~30),
>> many variables per node (~15), and some types of indexed variables with
>> many values per variable (~120).
>> The only thing that we wanted to be locked (between request and reply)
>> was the variable, to avoid sending commands on two different indexes of
>> the same variable without waiting for an answer.
>> Something like that does not fit the ASYN model well. For each fully
>> populated bus segment you would basically end up with ~450 instances of
>> a blocking "variable" port driver, all talking to the same non-blocking
>> lower level "bus" port driver. Starting 450 threads per bus made this
>> look very unattractive.
>> In the end we kept our patchwork non-ASYN driver, as (for this and other
>> reasons) the rewriting effort was not justified well enough.
>> ~Ralph
| Dr. Florian Feldbauer                |
| Helmholtz-Institut Mainz /           |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36         |
| D-55128 Mainz                        |
| Office: SB1 / 00-213                 |
| Phone:  (+49)6131 / 39-29605         |
Re: Question about device support Michael Davidsaver
Question about device support Florian Feldbauer
RE: Question about device support Mark Rivers
Re: Question about device support Florian Feldbauer
Re: Question about device support Ralph Lange
Prev: RE: CSS performance Shroff, Kunal
Next: Re: Question about device support Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Question about device support Florian Feldbauer
