1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn ModbusTCP communication KO without error messages
To: "'haquin'" <[email protected]>, tech-talk <[email protected]>
Date: Wed, 9 Sep 2015 16:01:58 +0000
I suspect your problem is indeed that suspended task.  Are you sure there was no error message when the task got suspended?
You can learn something about the task status by running the “tt” command on it:
tt 0x16963d0
Sent: Wednesday, September 09, 2015 6:44 AM
To: Mark Rivers; tech-talk
Subject: Re: Asyn ModbusTCP communication KO without error messages
Mark,
The problem happened again yesterday, I've attached files with the result of the several commands.
What I've noticed is that there is a PLC task that is suspended with a error code:
Errno 0x110003 => S_memLib_BLOCK_ERROR
  NAME         ENTRY       TID    PRI   STATUS      PC       SP     ERRNO  DELAY
LBE1-PLCV   a4c48c        167fb20 149 PEND         2c9038  1682b70       0     0
LBE1-PLCV-> a4c48c        1686000 149 PEND         2c7154  1689080       0     0
LBE1-PLCV-> a4c48c        168a9e0 149 PEND         2c7154  168c990      46     0
LBE1-PLCV-> a4c48c        168f510 149 PEND         2c7154  1692420       0     0
LBE1-PLCV-> a4c48c        16963d0 149 SUSPEND      2ce5c4  1699110  110003     0
LBE1-PLCV-> a4c48c        169c1b0 149 PEND         2c7154  169f0c0       0     0
LBE1-PLCV-> a4c48c        16a29c0 149 PEND         2c7154  16a58d0       0     0
LBE1-PLCV-> a4c48c        16a87c0 149 PEND         2c7154  16ab6d0       0     0
LBE1-PLCV-> a4c48c        16ae5c0 149 PEND         2c7154  16b14d0       0     0
LBE1-PLCV-> a4c48c        16b4280 149 PEND         2c7154  16b7190       0     0
LBE1-PLCV-> a4c48c        16ba620 149 PEND         2c7154  16bd6a0       0     0
LBE1-PLCV-> a4c48c        16c0420 149 PEND         2c7154  16c34a0       0     0
LBE1-PLCV-> a4c48c        16c6230 149 PEND         2c7154  16c92b0       0     0
LBE1-PLCV-> a4c48c        16cc030 149 PEND         2c7154  16cef40       0     0
- I don't think there is a deadlock, but I don't know what to expect with the output of the command in this case.
- There is no task overflow, especially the one that is suspended.
- The result of Asyn report is in attachment
I've added your Asyn record and there was the following errors when I tried to connect to the READ  port or set ON/OFF a trace:
iocVMELB1 > 2015/09/08 11:29:24.509 [LBE1-PLCV-READ,0,0] [../../asyn/asynDriver/asynManager.c:1509] [CAS-client,0x8f70500,20] LBE1-PLCV-READ addr 0 queueRequest priority 3 not lockHolder
2015/09/08 11:29:24.509 [LBE1-PLCV-READ,0,0] [../../asyn/asynDriver/asynManager.c:1520] [CAS-client,0x8f70500,20] LBE1-PLCV-READ schedule queueRequest timeout
2015/09/08 11:29:27.925 [LBE1-PLCV-READ,0,0] [../../asyn/asynDriver/asynManager.c:637] [timerQueue,0xc04f20,60] LBE1-PLCV-READ asynManager:queueTimeoutCallback
2015/09/08 11:29:27.925 [LBE1-PLCV-READ,0,0] [../../asyn/asynRecord/asynRecord.c:2003] [timerQueue,0xc04f20,60] LBE1-PLCV-asyn: special queueRequest timeout
2015/09/08 11:29:34.509 [LBE1-PLCV-READ,0,0] [../../asyn/asynDriver/asynManager.c:637] [timerQueue,0xc04f20,60] LBE1-PLCV-READ asynManager:queueTimeoutCallback
2015/09/08 11:29:34.509 [LBE1-PLCV-READ,0,0] [../../asyn/asynRecord/asynRecord.c:2003] [timerQueue,0xc04f20,60] LBE1-PLCV-asyn: special queueRequest timeout
iocVMELB1 > 2015/09/08 11:31:44.577 [LBE1-PLCV-READ,0,0] [../../asyn/asynRecord/asynRecord.c:899] [CAS-client,0x8f70500,20] LBE1-PLCV-asyn: exception 3
2015/09/08 11:31:51.910 [LBE1-PLCV-READ,0,0] [../../asyn/asynRecord/asynRecord.c:899] [CAS-client,0x8f70500,20] LBE1-PLCV-asyn: exception 4
2015/09/08 11:31:54.527 [LBE1-PLCV-READ,0,0] [../../asyn/asynRecord/asynRecord.c:899] [CAS-client,0x8f70500,20] LBE1-PLCV-asyn: exception 4
2015/09/08 11:31:57.244 [LBE1-PLCV-READ,0,0] [../../asyn/asynRecord/asynRecord.c:899] [CAS-client,0x8f70500,20] LBE1-PLCV-asyn: exception 3
2015/09/08 11:32:00.077 [LBE1-PLCV-READ,0,0] [../../asyn/asynRecord/asynRecord.c:899] LBE1-PLCV-asyn: exception 5
2015/09/08 11:32:03.277 [LBE1-PLCV-READ,0,0] [../../asyn/asynRecord/asynRecord.c:899] [CAS-client,0x8f70500,20] LBE1-PLCV-asyn: exception 5
Thanks for your help
best regards
Le 02/09/2015 16:46, Mark Rivers a écrit :
Hi Christophe,
Here are some things to look for:
- On vxWorks perhaps a task has been suspended.  Issue the "i" command to look at the status of all of the tasks.
- Perhaps there is a deadlock.  Issue this command several times in a row to see if there is a mutex that is always locked:
epicsMutexShowAll 1
- Perhaps there was a stack overflow.  Issue this command and look for tasks with a margin of 0
checkStack
If you don't find anything there then send us the output of "asynReport 10" on the Read port and Write port.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of haquin
Sent: Wednesday, September 02, 2015 9:00 AM
To: tech-talk
Subject: Asyn ModbusTCP communication KO without error messages
Hi all,
I have a VxWorks IOC (with MVME-CPU using both eth interfaces) communicating with a siemens S7PLC via Asyn/ModbusTCP.
EPICS release 3.14.12.4 Asyn v4.22
After a while  (1 or 2 days), the communication is not working anymore ... but I have no error messages (no timeout nor
disconnection ...).
 From IOC side I a have "Read Multiple Register" function reading the whole modbus table (109 registers) every second
and a "Write Multiple Register" function writing the value of a counter incremented every seconds from record level.
When I activate AsynTrace on IP Port or Read or Write ports there is no messages ...
asynReport on Read port indicates only 1 Read OK
asynReport on Write port indicates 0 Write OK
I can read the PLC register via "modpoll" tool from a Linux PC
I can start a Linux IOC connected to the same PLC
The netstat command on IOC shell tells that the TCP port is established but the Recv-Q is not equal to 0 (12 for example)
What can explain this behavior ?
thanks in advance !
Christophe Haquin
Control and Real Time systems Engineer
+33 231454661 office
+33 231454728 fax
SdA/GIM
GANIL
Bd Henri Becquerel BP 55027
14076 CAEN CEDEX5
Re: Asyn ModbusTCP communication KO without error messages haquin
RE: Asyn ModbusTCP communication KO without error messages Mark Rivers
Prev: RE: dxp-3-2 in windows7-x64 Mark Rivers
Next: RE: building labCA on base 3.15.2, missing tsDefs.h Gierman, Stephen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Asyn ModbusTCP communication KO without error messages Mark Rivers
Next: Re: Asyn ModbusTCP communication KO without error messages haquin
