1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: building labCA on base 3.15.2, missing tsDefs.h
To: "Straumann, Till" <[email protected]>, "'[email protected]'" <[email protected]>
Date: Wed, 9 Sep 2015 22:23:19 +0000
Till,
lcaGetEnumStrings IS working for me in matlab; I don't know why I had problems yesterday.  It's a nice feature -- thanks.
>> lcaGet('LTD-Q1D:Control')
Initializing labCA Release '$Name: labca_3_5_0 $'...
Author: Till Straumann <[email protected]>
ans =
    'DONE'
>> lcaGetEnumStrings('LTD-Q1D:Control')
ans =
    'DONE'    'RAMPOFF'    'RAMPON'    'RAMPDES'    'STANDARDIZE'    'RAMPZERO'    'RAMPMIN'    'RAMPRESTORE'    ''    ''    ''    ''    ''    ''    ''    ''
Steve
-----Original Message-----
Sent: Tuesday, September 08, 2015 8:09 PM
To: Gierman, Stephen; '[email protected]'
Subject: Re: building labCA on base 3.15.2, missing tsDefs.h
On 09/08/2015 02:43 PM, Gierman, Stephen wrote:
> Hi Till,
> Thanks for labCA-3.5.0.  I've built and tested it on windows-x64 and it mostly seems to be working.  I get an odd message when I build:
> C:\epics\R3.15.2\extensions\src\labca_3_5_0>make >
> make_labca_3_5_0.txt
> process_begin: CreateProcess(NULL, sed -n -e "s/\(.*[^b]subsection.*[{][ \t]*\)\(lca[a-zA-Z0-9]*\).*/\2/gp" manual.tex, ...) failed.
Thanks. That's luckily benign (safe to ignore) but nevertheless a bug in the makefile. The above command should not have to be executed unless documentation is rebuilt from the .tex file. I usually create docs during the release process so there is no need for 'sed' -- which may not be available under windows.
> And I may have a problem with the new lcaGetEnumStrings().  Here's what happens in matlab R2015a:
> Invalid MEX-file
> 'C:\epics\R3.15.2\extensions\src\labca_3_5_0\bin\windows-x64\labca\lcaGetEnumStrings.mexw64': The specified procedure could not be found.
Hmm - I'm not able to reproduce this. Works fine for me -- but the only matlab I have access to is
2012a/linux-x86 and 2014b/linux-x86_64.
Do the other entry points work (e.g., 'lcaGet()') ?
- Till
> Steve
> From: Till Straumann [mailto:[email protected]]
> Sent: Tuesday, September 08, 2015 12:56 PM
> Yeah. tsDefs is cruft from the old days.
> I just put up a new release (labca-3.5.0) which does away with tsDefs and TS_STAMP (replaced by epicsTime.h and epicsTimeStamp, respectively).
> This release also features a new call 'lcaGetEnumStrings()' which allows you to retrieve the set of possible values for enum-type PVs.
> Available as usual from
> http://www.slac.stanford.edu/~strauman/labca/
> - Till
> On 09/07/2015 03:23 PM, Gierman, Stephen wrote:
>> Hi,
>> I'm building labCA (version 3.4.2) on base-3.15.2 for 64-bit windows.  The build fails in the 'glue' directory when it cannot find the include file 'tsDefs.h'.  Indeed, I do not find tsDefs.h in base-3.15.2, but I do find it in base-3.14.12.2, though it seems to be deprecated there.  Here are the last few lines of the build:
>> cl -EHsc -GR            -DMATLAB_APP     -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -I../../../../../base/include/compiler/msvc -I../../../../../base/include/os/WIN32 -I../../../../../base/include           -I../../ezca -IC:\matlab\R2015a/extern/include    -c ../ini.cc
>> ini.cc
>> ..\multiEzca.h(32) : fatal error C1083: Cannot open include file:
>> 'tsDefs.h': No such file or directory
>> make[2]: Leaving directory `C:/epics/R3.15.2/extensions/src/labca_3_4_2/glue/O.windows-x64'
>> make[1]: Leaving directory `C:/epics/R3.15.2/extensions/src/labca_3_4_2/glue'
>> I'm not sure what to do next ...
>> Steve Gierman
building labCA on base 3.15.2, missing tsDefs.h Gierman, Stephen
Re: building labCA on base 3.15.2, missing tsDefs.h Till Straumann
RE: building labCA on base 3.15.2, missing tsDefs.h Gierman, Stephen
Prev: RE: Asyn ModbusTCP communication KO without error messages Mark Rivers
Next: SetVoltage problem info22
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: building labCA on base 3.15.2, missing tsDefs.h Till Straumann
Next: store data to hard disk l123173
