Subject: |
[Solved] g_file_read (used in aravislib, areadetector) fails when running on a remote machine via ssh |
Heinz Junkes <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Fri, 20 Nov 2015 17:24:08 +0100 |
Packets for gvfs (and gvfs-backends where missing) :-(
After installing
ii gvfs:amd64 1.20.3-0ubuntu1.2 amd64 userspace virtual filesystem - GIO module
ii gvfs-backends 1.20.3-0ubuntu1.2 amd64 userspace virtual filesystem - backends
ii gvfs-bin 1.20.3-0ubuntu1.2 amd64 userspace virtual filesystem - binaries
ii gvfs-common 1.20.3-0ubuntu1.2 all userspace virtual filesystem - common data files
ii gvfs-daemons 1.20.3-0ubuntu1.2 amd64 userspace virtual filesystem - servers
ii gvfs-libs:amd64 1.20.3-0ubuntu1.2 amd64 userspace virtual filesystem - private libraries
aravislib runs on an ioc too.
Heinz
> On 19 Nov 2015, at 15:00, Heinz Junkes <[email protected]> wrote:
> Hi all,
> I am still fighting with glib running within procserv (or remote via ssh).
> The aravislib used in areadetector to connect to GigE (Genicam) cameras uses glib.
> Running the stuff locally works well. Running it remotely it fails.
> Testfile:
> h1@earth:~/ARAVIS/aravis/tests$ more loadhttptest.c
> #include <glib.h>
> #include <gio/gio.h>
> #include <stdlib.h>
> #include <stdio.h>
> #include <arv.h>
> int
> main (int argc, char **argv)
> GFile *file;
> GFileInputStream *stream;
> const char *filename;
> char *genicam = NULL;
> char **tokens;
> gsize len = 0;
> GError *err = NULL;
> if (argc != 2) {
> printf ("Usage: load-http-test <URL>\n");
> return EXIT_FAILURE;
> filename = argv[1];
> tokens = g_regex_split (arv_gv_device_get_url_regex (), filename, 0);
> if (tokens[0] != NULL && tokens[1] != NULL) {
> if (g_ascii_strcasecmp (tokens[1], "http:") == 0) {
> file = g_file_new_for_uri (filename);
> stream = g_file_read (file, NULL, &err);
> if (err != NULL) {
> g_error("Could not open %s for reading: %s\n", filename, err->message);
> g_error_free(err);
> return 1;
> if(stream) {
> GDataInputStream *data_stream;
> data_stream = g_data_input_stream_new (G_INPUT_STREAM (stream));
> genicam = g_data_input_stream_read_upto (data_stream, "", 0, &len, NULL, NULL);
> g_object_unref (data_stream);
> g_object_unref (stream);
> g_object_unref (file);
> g_strfreev (tokens);
> printf ("size = %lu\n", len);
> printf ("%s\n", genicam != NULL ? genicam : "NULL");
> g_free (genicam);
> return EXIT_SUCCESS;
> Running it locally it shows:
> h1@earth:~/ARAVIS/aravis/tests$ ./load-http-test http://141.14.128.47/dias_gige_desc.xml
> size = 64451
> <?xml version="1.0" encoding="utf-8"?>
> <RegisterDescription
> ModelName="Pyroview"
> VendorName="DIAS"
> StandardNameSpace="None"
> SchemaMajorVersion="1"
> SchemaMinorVersion="0"
> SchemaSubMinorVersion="1"
> MajorVersion="1"
> MinorVersion=“ …
> <IntSwissKnife Name="NOT_TLParamsLocked">
> <ToolTip>Negation of the TLParamsLocked value</ToolTip>
> <Visibility>Invisible</Visibility>
> <pVariable Name="TLPL">TLParamsLocked</pVariable>
> <Formula>(TLPL = 0) ? 1 : 0</Formula>
> </IntSwissKnife>
> </RegisterDescription>
> Running it remote via ssh it shows :
> ** (process:11455): ERROR **: Could not open http://141.14.128.47/dias_gige_desc.xml for reading: Operation not supported
> Trace/breakpoint trap (core dumped)
> I assume problems with dbus/session/stream stuff. About one year ago I could overcome the problem by adding the
> following to the st.cmd used by procserv :
> #!/bin/bash
> PID_FILE=/tmp/dbus_pid
> if [ -a $PID_FILE ]
> then
> # echo "$PID_FILE exists ..."
> PID=`cat $PID_FILE`
> # echo "kill_pid $PID"
> kill -9 $PID
> fi
> if test -z "$DBUS_SESSION_BUS_ADDRESS" ; then
> ## if not found, launch a new one
> eval `dbus-launch --sh-syntax --exit-with-session`
> echo "D-Bus per-session daemon address is: $DBUS_SESSION_BUS_ADDRESS"
> echo "$DBUS_SESSION_BUS_PID" >$PID_FILE
> fi
> #date
> #sleep 1
> #/usr/local/bin/arv-tool-0.4 -n 'DIAS Infrared GmbH-C1076026' genicam >/tmp/dias_genicam.out
> #sleep 1
> #date
> cd /srv/ioc/sys/iocBoot/iocdias
> ./st.cmd
> #kill -9 $DBUS_SESSION_BUS_PID
> But this doesn’t help anymore.
> Any Ideas?
> Thx Heinz
smime.p7s
Description: S/MIME cryptographic signature
- g_file_read (used in aravislib, areadetector) fails when running on a remote machine via ssh Heinz Junkes
Re: synApps modules will move to GitHub: optics, softGlue, sscan, stream, support Pete Jemian
<2015>
2025
Successfully locked memory using mlockAll Henrique Dante de Almeida
<2015>
2025
