Hello, I'm testing EPICS base v 3.15 on a fresh Red Hat 6.6 instalation and after compiling, executing caget always returns the message "Successfully locked memory using mlockAll":
[root@SOL1-HOST1 linux-x86]# ./caget LNLS:ANEL:corrente
LNLS:ANEL:corrente 161.585
[root@SOL1-HOST1 linux-x86]# cd
[root@SOL1-HOST1 ~]# caget LNLS:ANEL:corrente
LNLS:ANEL:corrente 161.553
(etc.)
Can the message be removed ? Here is what seems to be the relevant commit:
https://code.launchpad.net/~mshankar/epics-base/memlock_linux/+merge/232466
- Re: Successfully locked memory using mlockAll Andrew Johnson
Re: synApps modules will move to GitHub: optics, softGlue, sscan, stream, support Pete Jemian
error: ‘dbChannel’ has no member named ‘final_dbr_type’ Henrique Dante de Almeida
<2015>
[Solved] g_file_read (used in aravislib, areadetector) fails when running on a remote machine via ssh Heinz Junkes
<2015>
