On 11/23/2015 01:20 PM, Henrique Dante de Almeida wrote:
> Hello, I'm testing EPICS base v 3.15 on a fresh Red Hat 6.6
> installation and after compiling, executing caget always returns
> the message "Successfully locked memory using mlockAll":
> [root@SOL1-HOST1 linux-x86]# ./caget LNLS:ANEL:corrente
> LNLS:ANEL:corrente 161.585
> [root@SOL1-HOST1 linux-x86]# cd
> [root@SOL1-HOST1 ~]# caget LNLS:ANEL:corrente
> LNLS:ANEL:corrente 161.553
> (etc.)
> Can the message be removed ? Here is what seems to be the relevant
> commit:
> https://code.launchpad.net/~mshankar/epics-base/memlock_linux/+merge/232466
Those messages will be printed to stderr if you run caget (or any other
program linked with our libCom library) as root. Using the root account
to run programs that don't need such privilege is a bad idea from a
computer security perspective though. Some sites do need to run certain
IOCs with root privilege to enable the real-time scheduler (which then
makes it desirable to lock the IOC code into physical RAM) or to access
certain I/O hardware from user-space, but in most cases we'd recommend
that you use a non-root account for programs like caget/caput/camonitor.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
-- Terry Pratchett, Reaper Man
- Re: Successfully locked memory using mlockAll Henrique Almeida
- Successfully locked memory using mlockAll Henrique Dante de Almeida
Re: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Pete Jemian
Missaligned protocol rejected when using caPutLog Qiao Yusi
<2015>
<2015>
