What is the version number of your mv6100 BSP? We use release 6.9/0 here
and it includes all those routines that your VxWorks image seems to be
missing:
tux% cd vxworks-6.9/target/config/mv6100/
tux% grep 'define BSP_' config.h
#define BSP_VERSION "6.9" /* vxWorks 6.9 */
#define BSP_REV "/0" /* 0 for first revision */
tux% grep sysPci sysAUtil.s
FUNC_EXPORT(sysPciInByte)
FUNC_EXPORT(sysPciOutByte)
FUNC_EXPORT(sysPciInWord)
FUNC_EXPORT(sysPciOutWord)
FUNC_EXPORT(sysPciInLong)
FUNC_EXPORT(sysPciOutLong)
* sysPciInByte - reads a byte from PCI Config Space.
FUNC_BEGIN(sysPciInByte)
FUNC_END(sysPciInByte)
* sysPciInWord - reads a word (16-bit big-endian) from PCI Config Space.
FUNC_BEGIN(sysPciInWord)
FUNC_END(sysPciInWord)
* sysPciInLong - reads a long (32-bit big-endian) from PCI Config Space.
FUNC_BEGIN(sysPciInLong)
FUNC_END(sysPciInLong)
* sysPciOutByte - writes a byte to PCI Config Space.
FUNC_BEGIN(sysPciOutByte)
FUNC_END(sysPciOutByte)
* sysPciOutWord - writes a word (16-bit big-endian) to PCI Config Space.
FUNC_BEGIN(sysPciOutWord)
FUNC_END(sysPciOutWord)
* sysPciOutLong - writes a long (32-bit big-endian) to PCI Config Space.
FUNC_BEGIN(sysPciOutLong)
FUNC_END(sysPciOutLong)
- Andrew
On 01/05/2016 03:56 PM, 김지화(빔라인장치팀) wrote:
> Hi Martin,
> We are using CentOS 6.5 linux and ioc code from the https://github.com/epics-modules/mrfioc2/
> and ver 2.4 from the https://github.com/epics-modules/devlib2
> Thanks,
> Ji-Hwa
> 보낸 사람: [email protected] <[email protected]> 대신 Konrad, Martin <[email protected]>
> 보낸 날짜: 2016년 1월 6일 수요일 오전 6:26
> 받는 사람: [email protected]
> 제목: Re: mrfioc2 loading error at vxWorks 6.9
> Hi Ji-Hwa,
> Are you building from the tarballs or are you using the Debian packages?
> Which version of devlib2 are you using?
> -Martin
> On 01/05/2016 03:59 PM, 김지화(빔라인장치팀) wrote:
>> Hello All,
>> Recently when I test a MRF event board, I found a VxWorks “mrf.munch”
>> loading errors with MVME6100 VME board.
>> Used packages:
>> epics Base 3.15.3
>> mrfioc 2.0.4
>> devlib2
>> VxWorks 6.9
>> Workbench 3.3
>> -> ld < mrf.munch
>> Warning: module 0x4353af0 holds reference to undefined symbol
>> _Z13sysPciOutLongPjj.
>> _Z13sysPciOutWordPtt.
>> _Z12sysPciInWordPt.
>> _Z12sysPciInLongPj.
>> _Z12sysPciInBytePh.
>> _Z13sysPciOutBytePhh.
>> ld(): module contains undefined symbol(s) and may be unusable.
>> Please give any suggestions and comments.
>> Thanks,
>> Ji-Hwa Kim
>> PAL-XFEL Project
>> Pohang Accelerator Laboratory
>> 80 Jigokro-127-Beongil, Nam-gu, Pohang, Gyeongbuk
>> 37673, Korea
> Martin Konrad
> Control System Engineer
> Facility for Rare Isotope Beams
> Michigan State University
> 640 South Shaw Lane
> East Lansing, MI 48824-1321, USA
> Tel. 517-908-7253
> Email: [email protected]
There are only two hard problems in distributed systems: 2. Exactly-once
delivery 1. Guaranteed order of messages 2. Exactly-once delivery
-- Mathias Verraes
- Re: mrfioc2 loading error at vxWorks 6.9 Bjorklund, Eric A
- Re: mrfioc2 loading error at vxWorks 6.9 Konrad, Martin
- RE: mrfioc2 loading error at vxWorks 6.9 김지화(빔라인장치팀)
<2016>
<2016>
