Subject: |
terminal server/serial server/console management switch recommendations? |
Maren Purves <[email protected]> |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Fri, 08 Jan 2016 15:29:15 -1000 |
Hi all,
we have a number of serial line devices connected to a number
of IOCs (at 2 telescopes) examples are Lakeshore, Omega DP1s,
WXTs, Edwards gauges. Of old we are/were using Emulex terminal
servers but these things are getting up there in the years and
we lost a few already and had to replace them and we expect more
of them to go.
We have a few WTI CMS console management switches of an older
generation that we use to access computer consoles but I'm
not sure we currently have any measuring devices attached to
them. They work well with computers, including IOCs, once they
are set up to not use ^X as their disconnect character.
More recently we got some of these of a newer generation and we
have problems with them. One of the problems I have seen is that
even after configuring all ports to not have ^X as their disconnect
character they'll still send out ^Xs, and another problem that we
have a lot more frequently is that they don't drop the old connections
when one reboots an IOC. Currently the fastest way to reboot an IOC
is to halt it, manually disconnect all the serial ports and then
boot.
What are other people using, and would you recommend what you're
using or don't you?
Maren
- Re: terminal server/serial server/console management switch recommendations? Eric Norum
- RE: terminal server/serial server/console management switch recommendations? Mark Rivers
- Re: terminal server/serial server/console management switch recommendations? Ryan Pierce
- RE: terminal server/serial server/console management switch recommendations? Mazanec Tomáš
- Re: terminal server/serial server/console management switch recommendations? Ralph Lange
Re: mrfioc2 loading error at vxWorks 6.9 Andrew Johnson
<2016>
2025
Re: Can I override record definition twice in an IOC Andrew Johnson
<2016>
2025
