1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Motor record with encoders
Cc: "[email protected] Talk" <[email protected]>
Date: Thu, 18 Feb 2016 17:54:47 -0200
2016-02-18 17:37 GMT-02:00 Mark Rivers <[email protected]>:
Hi Henrique,
There is no online tutorial on model 3 drivers.  That needs to be done ...
I have created Doxygen documentation for the Model 3 classes.  Here is a link:
http://cars.uchicago.edu/software/epics/motorDoxygenHTML/classasyn_motor_controller.html
I gave a talk on asynMotor at the MOCRAF workshop at the ICALEPCS conference in San Francisco.  It is posted online here:
http://www.synchrotron-soleil.fr/images/File/Informatique/Workshop-Motion/Talks/TT07_APS_MarkRivers-EPICSCoordinatedMotion.pdf
I have also attached a talk I gave that describes the Model 3 architecture.
There are a number of drivers you can use as examples:
- ACS-MCB4B.  This is a simple driver.  The motorApp/AcsSrc directory contains both an old Model 1 driver (devMCB4B.cc, drvMCB4B.cc) and a new Model 3 driver (MCB4BDriver.cpp).  You should use the latter.
- Parker ACR controller (motorApp/ACRSrc/ACRMotorDriver.cpp.  This is also a simple driver.
 I have browsed ACRMotorDriver.cpp and MCB4Driver.cpp and it looks like they have almost everything I need. I was unable to find out how to deal with MRES/SREV, ERES and UEIP, however. Is there a specific file where I should look ?
- Newport XPS controller (motorApp/NewportSrc/XPSController.cpp, XPSAxis.cpp).  This is a more complex driver that support complex coordinated motion and some other features.
The following is a list of all “.cpp” files in the motorApp directories, and I think these are all Model 3 drivers.
corvette:~/devel/motor>find . -name '*.cpp'
./motorApp/NPointSrc/C300MotorDriver.cpp
./motorApp/PhytronSrc/phytronAxisMotor.cpp
./motorApp/MicroMoSrc/MVP2001Driver.cpp
./motorApp/ImsSrc/ImsMDrivePlusMotorAxis.cpp
./motorApp/ImsSrc/ImsMDrivePlusMotorController.cpp
./motorApp/PIGCS2Src/PIE755Controller.cpp
./motorApp/PIGCS2Src/PIGCSPiezoController.cpp
./motorApp/PIGCS2Src/PIGCSMotorController.cpp
./motorApp/PIGCS2Src/PIGCS2_HexapodController.cpp
./motorApp/PIGCS2Src/PIE517Controller.cpp
./motorApp/PIGCS2Src/PIC702Controller.cpp
./motorApp/PIGCS2Src/PIasynAxis.cpp
./motorApp/PIGCS2Src/PIInterface.cpp
./motorApp/PIGCS2Src/PIasynController.cpp
./motorApp/PIGCS2Src/PIGCSController.cpp
./motorApp/PIGCS2Src/PIHexapodController.cpp
./motorApp/ACRSrc/ACRMotorDriver.cpp
./motorApp/SmarActMCSSrc/smarActMCSMotorDriver.cpp
./motorApp/MicosSrc/SMChydraDriver.cpp
./motorApp/HytecSrc/HytecMotorDriver.cpp
./motorApp/OmsAsynSrc/omsMAXv.cpp
./motorApp/OmsAsynSrc/omsMAXvEncFunc.cpp
./motorApp/OmsAsynSrc/omsMAXnet.cpp
./motorApp/OmsAsynSrc/omsBaseController.cpp
./motorApp/OmsAsynSrc/omsBaseAxis.cpp
./motorApp/NewportSrc/AG_CONEX.cpp
./motorApp/NewportSrc/SMC100Driver.cpp
./motorApp/NewportSrc/HXPDriver.cpp
./motorApp/NewportSrc/XPSController.cpp
./motorApp/NewportSrc/XPSAxis.cpp
./motorApp/NewportSrc/AG_UC.cpp
./motorApp/MicronixSrc/MMC200Driver.cpp
./motorApp/AcsSrc/MCB4BDriver.cpp
Cheers,
Sent: Thursday, February 18, 2016 1:17 PM
To: Mark Rivers
Cc: [email protected] Talk
2016-02-18 17:09 GMT-02:00 Mark Rivers <[email protected]>:
You may be able to just load another record that periodically writes to the STUP field?  What are your requirements?
 That would do.
What driver are you using?
 It's called "motorPXI", it's a proxy driver that communicates via shared memory with a LabView RT application, which contains the real driver.
If you want to switch to Model 3 then yes you need to rewrite the driver.  Model 3 is quite a simple model.  You just need to implement some C++ methods like asynMotorAxis:: move(), asynMotorAxis::stop(), asynMotorAxis::poll(), etc.
 Is there an example implementation or tutorial ?
Sent: Thursday, February 18, 2016 1:05 PM
To: Mark Rivers
 I believe the motor driver is using model 1 (motor*Com.cc) API. Is it necessary to rewrite the driver to support model 3 ?
2016-02-18 16:59 GMT-02:00 Mark Rivers <[email protected]>:
Yes the motor record can update REP when all motors are stopped.  If you are using a “Model 2” or “Model 3” driver that does callbacks when the motor is idle then the record will automatically process and update.  If you are using a “Model 1” driver then you need to write to the STUP field to force the record to read the status.
From: [email protected] [mailto:[email protected]] On Behalf Of Henrique Almeida
Sent: Thursday, February 18, 2016 12:50 PM
To: [email protected] Talk
Subject: Motor record with encoders
 Hello, is the motor record currently able to update the encoder position ("REP" PV) while all motors are stopped ?
RE: Motor record with encoders Mark Rivers
Motor record with encoders Henrique Almeida
Re: Motor record with encoders Henrique Almeida
Prev: Re: Motor record with encoders Henrique Almeida
Next: RE: Motor record with encoders Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
