1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: NDTransform Plugin does not work
Date: Mon, 14 Mar 2016 14:50:07 +0000
Hi Yihui,
                I could not open your first attachment “screenshot_NDTransform.png”.  The second one looks slight different from mine, which has an ‘Array callback enable/disable’ button.  I have to assume yours has been ‘enabled’.
My guess would be that you need to set the plugin port for the Image1 and FileTIFF1 to read from this TRANS1 port to see the image transformed in the ImageJ display and/or saved Tiff file, respectively.  Those can be set through: Main panelàAll button in the Plugins subpanel, assuming you are using a generic main adl panel for your detector.
Zhan
Zhan Zhang, Ph. D.
Argonne National Laboratory
X-ray Science Division, 438-D005
9700 S. Cass Ave.
Argonne, IL 60439
Tel : 630-252-0863
Email: [email protected]
From: [email protected] [mailto:[email protected]] On Behalf Of Xu, Yihui
Sent: Monday, March 14, 2016 9:11 AM
To: [email protected]
Subject: NDTransform Plugin does not work
Dear all
I have tried to use the NDTransform Plugin to rotate my images, however, no matter use the old version or the new version by Christian Roehrig, neither my saved Tiff-file nor imagej ADlive viewer show any change.
Attached please find my settings for both the NDtranform plugins.
Cheers
Yihui
NDTransform Plugin does not work Xu, Yihui
Prev: NDTransform Plugin does not work Xu, Yihui
Next: RE: NDTransform Plugin does not work Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
