1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: NDTransform Plugin does not work
To: "'Xu, Yihui'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 14 Mar 2016 14:52:41 +0000
Hi Yihui,
I suspect the problem is that you have not told the NDFileTIFF plugin or the NDStdArrays plugin for ImageJ to get their data from the NDTransform plugin.  They are probably getting their data directly from the detector, which is asyn port TIM in your case.  You need to set the NDArrayPort PV in the NFFileTIFF and NDStdArrays plugin to TRANS1, not TIM.
From: [email protected] [mailto:[email protected]] On Behalf Of Xu, Yihui
Sent: Monday, March 14, 2016 9:11 AM
To: [email protected]
Subject: NDTransform Plugin does not work
Dear all
I have tried to use the NDTransform Plugin to rotate my images, however, no matter use the old version or the new version by Christian Roehrig, neither my saved Tiff-file nor imagej ADlive viewer show any change.
Attached please find my settings for both the NDtranform plugins.
Cheers
Yihui
NDTransform Plugin does not work Xu, Yihui
Prev: RE: NDTransform Plugin does not work Zhang, Zhan
Next: Scan problem when the ioc behave as client Tasaddaq Khan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: NDTransform Plugin does not work Mark Rivers
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
