1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: FFT and waveform
To: "'Mark Rivers'" <[email protected]>, "'[email protected]'" <[email protected]>
Cc: "Jan Marjanovic \([email protected]\)" <[email protected]>
Date: Mon, 28 Mar 2016 16:00:35 +0000
Hello Mark,
Indeed my inquiry is related to TetrAMM. The TetrAMM has two interfaces: Cat6 ethernet beamline network, and LC fiber (connected to BEST FPGA feedback system). The digital current measurement data flow through both interfaces simultaneously.
The 1G Ethernet communication is process by quadEM module and provides many areaDetector features including the upcoming FFT update.
In addition, CAENels released open version of the BEST ioc this month, and I have started using it.
GitHub: https://github.com/CAENels/best-epics-ioc
The view through BEST FPGA system allows information about implemented (piezo) feedback, in addition to passive monitoring that quadEM allows. However, the BEST IOC is missing some useful features like FFT. Adding FFT would enhance it.
Kaz
Sent: Sunday, March 27, 2016 1:27 PM
To: Gofron, Kazimierz; '[email protected]'
Hi Kaz,
This is from the areaDetector/ADCore release notes for the upcoming R2-5 release.  These items are available now in the master branch on github.
### NDPluginFFT
* New plugin to compute 1-D or 2-D Fast Fourier transforms.  It exports 1-D or 2-D
  NDArrays containing the absolute value of the FFT.  It creates 1-D waveform
  records of the input, and the real, imaginary, and absolute values of the first row of the FFT.
  It also creates 1-D waveform records of the time and frequency axes, which are useful if the 1-D
  input represents a time-series. The waveform records are convenient for plotting in OPI screens.
* The FFT algorithm requires that the input array dimensions be a power of 2, but the plugin
  will pad the array to the next larger power of 2 if the input array does not meet this
  requirement.
*  The simDetector test application in
  [areaDetector/ADExample](https://github.com/areaDetector/ADExample)
  has a new simulation mode that generates images based on the sums and/or products of 4 sine waves.
  This application is useful for testing and demonstrating the NDPluginFFT plugin.
This is from the areaDetector/ADExample notes for the upcoming R2-2 release.  These items are available now in the master branch on github.
* Created a new driver in ADExample/exampleApp/ADCSimDetectorSrc.
  This driver generates times-series data for 8 signals as a 2-D array [8, NumTimePoints].
  The signals are common waveforms (sine, cosine, square wave, sawtooth, random noise, etc.)
  The driver was written in part to test the new NDPluginTimeSeries and NDPluginFFT plugins
  in ADCore R2-5. But it can also serve as a starting point for writing drivers that are used
  to collect time-series data like ADCs, waveform digitizers, etc.
  There is a new iocs/iocADCSimDetector directory that creates an application for testing
  the driver.
* Added a new sine-wave simulation mode to simDetector.  This simulation mode constructs images
  as the sum or products of two sine waves in the X and Y directions.  It was designed in part
  to test the new NDPluginFFT plugin in ADCore R2-5.
From: [email protected] [mailto:[email protected]] On Behalf Of Gofron, Kazimierz
Sent: Sunday, March 27, 2016 11:24 AM
To: '[email protected]'
Subject: FFT and waveform
Hi all,
My waveform (1024 current reading in [A], @1s) needs to be processed for frequencies using FFT method. The current values are in range between pA and mA ranges.
There is an existing tech-talk exchange on FFT from about 5 years ago that discuss FFT3, fftw, and waveProc.
FFT3 based:
http://www.aps.anl.gov/epics/tech-talk/2011/msg01143.php
http://www.fftw.org/fftw3_doc/Complex-DFTs.html#Complex-DFTs
The github fftw development:
https://github.com/FFTW/fftw3
The waveProc is bit dated (2004?)
http://www.aps.anl.gov/epics/download/modules/index.php
Any newer solutions and suggestions?
Kazimierz Gofron
NSLS-II Controls Group
Brookhaven National Laboratory
(p) +1 (631) 344 5283
(f) +1 (631) 344 8085
(e) [email protected]
(w) www.bnl.gov/nsls2
RE: FFT and waveform Mark Rivers
FFT and waveform Gofron, Kazimierz
Prev: RE: Question about the connection refused Mark Rivers
Next: RE: FFT and waveform Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: FFT and waveform Mark Rivers
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
