1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Dropped frames from GigE cameras on Linux
Date: Thu, 21 Apr 2016 18:18:48 +0000
Folks,
I find that people frequently have problems with dropped frames when running GigE cameras on Linux, particularly under heavy CPU loading.
In 2013 I posted a message to tech-talk (http://www.aps.anl.gov/epics/tech-talk/2013/msg02491.php) about this problem.  It contained a link from Tom Cobb to a Point Grey Knowledge Base article with a solution, which involves increasing some system values as follows:
sudo sysctl -w net.core.rmem_max=1048576 net.core.rmem_default=1048576
I  found today that the Point Grey link in that message no longer works.  However, here is a new link that does work.
http://www.ptgrey.com/KB/10016
Re: Dropped frames from GigE cameras on Linux Henrique Almeida
Prev: Re: Script BOY IntensityGraph to show areaDetector output of variable size Phil Atkin
Next: Brookhaven National Laboratory - Job Opening Esposito, Peter J
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to use registry to replace vxWorks symLib? Andrew Johnson
Next: Re: Dropped frames from GigE cameras on Linux Henrique Almeida
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
