1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Dropped frames from GigE cameras on Linux
Cc: "[email protected] Talk" <[email protected]>
Date: Sat, 23 Apr 2016 16:08:20 -0300
It's better not to change rmem_default, or most sockets in the system will have an increased buffer size. Instead, using setsockopt() will increase the buffer size only for the camera.
Also, a 1 MB buffer may not be enough, since it represents a 8 ms buffer in a 1 Gbps network. It is common for an application to be preempted for dozens of milliseconds under heavy load. I'm currently testing 2 MB for our non-GigE camera server. Our camera, however, does not support packet retransmissions, while the GigE protocol does.
Em 21/04/2016 15:19, "Mark Rivers" <[email protected]> escreveu:
Folks,
I find that people frequently have problems with dropped frames when running GigE cameras on Linux, particularly under heavy CPU loading.
In 2013 I posted a message to tech-talk (http://www.aps.anl.gov/epics/tech-talk/2013/msg02491.php) about this problem.  It contained a link from Tom Cobb to a Point Grey Knowledge Base article with a solution, which involves increasing some system values as follows:
sudo sysctl -w net.core.rmem_max=1048576 net.core.rmem_default=1048576
I  found today that the Point Grey link in that message no longer works.  However, here is a new link that does work.
http://www.ptgrey.com/KB/10016
RE: Dropped frames from GigE cameras on Linux Mark Rivers
Prev: Brookhaven National Laboratory - Job Opening Esposito, Peter J
Next: RE: Dropped frames from GigE cameras on Linux Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Dropped frames from GigE cameras on Linux Mark Rivers
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
