1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS 3.14.12.3 Build Problems with the new Ubuntu 16.04 LTS
Date: Tue, 26 Apr 2016 08:38:30 +0000
Hello all,
As you may already know, last Thursday was the release of the new Ubuntu 16.04 LTS. We decided to take a look at it and test our control system tools starting with EPICS.
I installed the OS on VMware Workstation, when doing the build, these are the error messages that appeared:
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include        ../epicsCalcTest.cpp
../epicsCalcTest.cpp: In function ‘int main(int, char**)’:
../../../../include/os/Linux/epicsMath.h:22:21: error: non-floating-point argument in call to function ‘__builtin_isfinite’
#  define finite(x) isfinite(x)
../epicsCalcTest.cpp:102:40: note: in definition of macro ‘testExpr’
#define testExpr(expr) testCalc(#expr, expr);
../epicsCalcTest.cpp:314:14: note: in expansion of macro ‘finite’
     testExpr(finite(0));
../epicsCalcTest.cpp:328:14: error: non-floating-point argument in call to function ‘__builtin_isinf_sign’
     testExpr(isinf(0));
../epicsCalcTest.cpp:332:14: error: non-floating-point argument in call to function ‘__builtin_isnan’
     testExpr(isnan(0));
../../../../configure/RULES_BUILD:209: recipe for target 'epicsCalcTest.o' failed
make[3]: *** [epicsCalcTest.o] Error 1
make[3]: Leaving directory '/home/abdalla/epics/base-3.14.12.3/src/libCom/test/O.linux-x86_64'
../../../configure/RULES_ARCHS:63: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/abdalla/epics/base-3.14.12.3/src/libCom/test'
../configure/RULES_DIRS:70: recipe for target 'libCom/test.install' failed
make[1]: *** [libCom/test.install] Error 2
make[1]: Leaving directory '/home/abdalla/epics/base-3.14.12.3/src'
configure/RULES_DIRS:70: recipe for target 'src.install' failed
make: *** [src.install] Error 2
A quick search over the Internet shows that some people have faced this error with the same GCC 5.3 compiler and the solution was to add a simple cast to float to the argument that caused the error.
The two needed files are:
1.       epicsCalcTest.cpp (located at base/src/libCom/test)
2.       epicsMath.h (located at base/src/libCom/osi/os/posix)
You can see the attached patch file for more details (which is applied on the base's top level folder). After doing the modifications in the patch file, the build works fine producing all EPICS binaries.
The question is, could there be another way to bypass this error? I think something can be done on the compiler side especially it is the new GCC 5.3 since the same EPICS version worked on Ubuntu 15.04 and 14.04 LTS without any problem (can't recall GCC version here).
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME.
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo
Attachment: base-3.14-gcc-5.3.patch
Description: base-3.14-gcc-5.3.patch
Re: EPICS 3.14.12.3 Build Problems with the new Ubuntu 16.04 LTS Michael Davidsaver
Prev: RE: Area Detector question ulrik.pedersen
Next: Generating log output from areaDetector IOC Phil Atkin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Area Detector question bob dalesio
Next: Re: EPICS 3.14.12.3 Build Problems with the new Ubuntu 16.04 LTS Michael Davidsaver
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
