1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: asyn: what if a driver wants to force callbacks?
To: <[email protected]>
Date: Thu, 26 May 2016 07:52:59 +0200
To my knowledge,
there is no update.
In our driver, we do it like this:
    /* If not moving, trigger a record processing at low rate */
    if (!nowMoving) setDoubleParam(pC_->motorPosition_, newPositionInSteps + 1);
    setDoubleParam(pC_->motorPosition_, newPositionInSteps);
And I added a test case:
https://github.com/EuropeanSpallationSource/MCAG_Base_Project/blob/master/epics/test/500_DLY-STOP.py
Out of curiosity:
Which kind of device are you using ?
On 25/05/16 23:50, Ford, Christopher wrote:
In 2015 there was some discussion on Tech-Talk about how to force a callback for a parameter that had not changed values.
Mark Rivers suggested a work-around, as shown below.
I wonder if anyone has an update on the situation since then?  Has any other method appeared?  Or did you have success with the work-around?
 -Chris Ford, SLAC
On16 Nov 2015 Mark Rivers writes:
If a driver wants to force a callback there is a method that does not require any changes to the base classes, e.g. exposing statusChanged_ as protected or adding a new
isMotorRecordnowFilterButAlwaysProcess_ flag.  The driver simply needs to set a parameter to a different value from present and then back to its current value, for example
 setDoubleParam(pC_->motorPosition_(position+1.);
 setDoubleParam(pC_->motorPosition_(position);
 callParamCallbacks();
Re: asyn: what if a driver wants to force callbacks? Mark Davis
Re: asyn: what if a driver wants to force callbacks? Ford, Christopher
Area Detector question Jörn Wüstenfeld
RE: Area Detector question ulrik.pedersen
RE: Area Detector question Mark Rivers
Prev: RE: asyn build on cygwin fails freddie.akeroyd
Next: RE: EPICS meeting : HW platform support discussion group tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: asyn: what if a driver wants to force callbacks? Ford, Christopher
Next: Re: asyn: what if a driver wants to force callbacks? Mark Davis
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
