1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: archiver appliance vs. data browser
To: <[email protected]>
Date: Fri, 27 May 2016 15:20:13 +0200
Martin,
you have to install the pbrawclient as well.
Can be found here:
https://github.com/slacmshankar/epicsarchiverap_pbrawclient/
HTH,
Heinz
On 2016-05-27 14:11, Schmeißer wrote:
Dear epics experts,
I would like to use the CSS data browser to look at strip plots and
access archived data from an archiver appliance that runs on the same
box in a VM.
I tried to configure the Archive Data Server URL as
pbraw://192.168.72.131:17665/retrieval
following the instructions at
http://slacmshankar.github.io/epicsarchiver_docs/csstudio.html
Unfortunately, CSS says
Error connecting to archive Server
URL pbraw://192.168.72.131:17665/retrieval
Detail: Unknown archive reader URL pbraw://192.168.72.131:17665/retrieval
when I open the Archive Search Panel.
Do you have any hints?
What is the correct URL to access the Archiver from CSS?
The archiver is the snapshot from May 13th, on Debian 8 64bit, and
was set up mostly following the quick start guide,
CSS is the "Basic EPICS" version 4.1.1 from ORNL on Win7 64.
I can get data from the archiver using MATLAB like this:
urlwrite('http://192.168.72.131:17665/retrieval/data/getData.mat', ...
    'temp.mat', 'get', ...
    {'pv', 'prep:rdPress', 'from', '2016-05-27T10:00:00.000+02:00',
'to', '2016-05-27T13:15:00.000+02:00'})
and i can access the Archiver's web interface.
Many thanks for any Ideas!
Kind regards,
Martin
Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
Forschungszentren e.V.
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch,
stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
RE: archiver appliance vs. data browser michael.kenning
archiver appliance vs. data browser Schmeißer, Martin
Prev: Re: asyn: what if a driver wants to force callbacks? Mark Rivers
Next: Re: asyn: what if a driver wants to force callbacks? Henrique Almeida
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: archiver appliance vs. data browser Schmeißer, Martin
Next: RE: archiver appliance vs. data browser michael.kenning
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
