1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: archiver appliance vs. data browser
To: <[email protected]>
Date: Fri, 27 May 2016 14:06:50 +0000
Dear Martin,
I encountered the same error as you have when I tried to use the data viewer in CS-Studio to view Archiver Appliance data.
First of all, make sure that you are using the right port number for the retrieval web app. Mine runs on 17668 by default.
In order to view data with the CS-Studio, you do need to install the pbraw client plugin as the last person in this thread said. However I think I remember trying to build that code and simply adding it to the plugins doesn't work. (Or I found that I couldn't build it.)
In any case, we got CS-Studio working by including the Archiver Appliance pbraw client into a new build of CS-Studio. The plugin ID is org.csstudio.archive.reader.appliance (I'm using version 1.0.1.201602291313), and it's called 'Archiver Appliance Reader'.
Hope this helps.
Kind regards,
Michael Kenning
Student Intern
Diamond Light Source Ltd.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of junkes
Sent: 27 May 2016 14:20
To: [email protected]
Subject: Re: archiver appliance vs. data browser
Martin,
you have to install the pbrawclient as well.
Can be found here:
https://github.com/slacmshankar/epicsarchiverap_pbrawclient/
HTH,
Heinz
On 2016-05-27 14:11, Schmeißer wrote:
> Dear epics experts,
> I would like to use the CSS data browser to look at strip plots and
> access archived data from an archiver appliance that runs on the same
> box in a VM.
> I tried to configure the Archive Data Server URL as
> pbraw://192.168.72.131:17665/retrieval
> following the instructions at
> http://slacmshankar.github.io/epicsarchiver_docs/csstudio.html
> Unfortunately, CSS says
> Error connecting to archive Server
> URL pbraw://192.168.72.131:17665/retrieval
> Detail: Unknown archive reader URL
> when I open the Archive Search Panel.
> Do you have any hints?
> What is the correct URL to access the Archiver from CSS?
> The archiver is the snapshot from May 13th, on Debian 8 64bit, and was
> set up mostly following the quick start guide, CSS is the "Basic
> EPICS" version 4.1.1 from ORNL on Win7 64.
> I can get data from the archiver using MATLAB like this:
> urlwrite('http://192.168.72.131:17665/retrieval/data/getData.mat',
>     'temp.mat', 'get', ...
>     {'pv', 'prep:rdPress', 'from', '2016-05-27T10:00:00.000+02:00',
> 'to', '2016-05-27T13:15:00.000+02:00'})
> and i can access the Archiver's web interface.
> Many thanks for any Ideas!
> Kind regards,
> Martin
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch,
> stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas
> Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
archiver appliance vs. data browser Schmeißer, Martin
Re: archiver appliance vs. data browser junkes
Prev: Re: asyn: what if a driver wants to force callbacks? Henrique Almeida
Next: Re: asyn: what if a driver wants to force callbacks? Ford, Christopher
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: archiver appliance vs. data browser junkes
Next: RE: archiver appliance vs. data browser Schmeißer, Martin
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
