1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Merlin and AreaDetector
To: "Gofron, Kazimierz" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 13 Jun 2016 03:13:08 +0000
Hi Kaz,
When we borrowed that detector and used areaDetector to save images they were 512x512, not 516x516.  Joanne Stubbs said she thinks there may be some different options on how to handle edge pixels, so perhaps your settings are different from ours.
Sent: Friday, June 10, 2016 7:51 PM
To: Mark Rivers; [email protected]
Thanks Mark on poiners to increase the number of ROI regions. Both modifications of screens, and commonPlugins is easy enough.
It is a loaner quad Merlin, and i am working with it for last 2 days. Perhaps I am still overlooked something.
Strangely enough, the image from Merlin seems to be 516x516 pixels, and not 512x512 the way documentation indicates, and ADMerlin has it setup.
Kaz
Sent from my Sprint Samsung Galaxy Note5.
-------- Original message --------
Date: 6/10/16 6:45 PM (GMT-05:00)
To: "Gofron, Kazimierz" <[email protected]>, [email protected]
Hi Kaz,
> However, for the current application, we need 6 ROI regions, but AD provides only 4 ROI regions. Would increasing number of ROI regions to 6 in areaDetector be standardized?
4 NDPluginROI plugins are loaded in the example commonPlugins.cmd file.  You are free to edit that file to load more, or instantiate additional plugins in the st.cmd file in addition to those created in commonPlugins.cmd.  You will also need to modify the OPI screen to access the additional plugins.  Many sites customize what plugins are loaded, either not loaded unused plugins, loading additional instances of standard plugins, or loading new site-specific plugins they have written.
Those communication errors with the LabView socket server do not look correct.  I don't recall seeing those, but I only had the detector for a couple of weeks and so did not spend a lot of time testing it.
Is this a purchased unit or their loaner?
-----Original Message-----
From: Gofron, Kazimierz [mailto:[email protected]<redir.aspx?REF=Im7ztHz_clyDLFxbGzMrIw6-RY7nDnulWbyrpFnJAxPKNPFzOJPTCAFtYWlsdG86a2dvZnJvbkBibmwuZ292>]
Sent: Friday, June 10, 2016 5:19 PM
To: [email protected]
Cc: [email protected]
Subject: Merlin and AreaDetector
Dear all,
For Merlin Quad detector, I compiled ADMerlin with newest AreaDetector (2.5?), and things seem to work properly. However, for the current application, we need 6 ROI regions, but AD provides only 4 ROI regions. Would increasing number of ROI regions to 6 in areaDetector be standardized?
2. I am also seeing the "labview" messages in the ioc which may or may not be important.I am wondering if this is anything to worry about???
iocInit()
Starting iocInit
## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$
## EPICS Base built Dec  2 2015
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from '/epics/iocs/merlinIOC/as/save/auto_settings.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
*** restoring from '/epics/iocs/merlinIOC/as/save/auto_settings.sav' at initHookState 7 (after record/device init) ***
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 57841,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30,"P=XF:10IDD-ES{Merlin:1}")
save_restore:readReqFile: unable to open file sseq_settings.req. Exiting.
epics> auto_settings.sav: 826 of 826 PV's connected
2016/06/10 18:02:42.811 medipixDetector:mpxReadCmd error, status=1 unexpected response from labview: ''
2016/06/10 18:02:42.811 medipixDetector:writeFloat64 error, status=1 function=91, value=20.000000
2016/06/10 18:02:42.812 XF:10IDD-ES{Merlin:1}cam1:OperatingEnergy devAsynFloat64 pPvt->result.status=1, process error
2016/06/10 18:02:44.814 medipixDetector:mpxReadCmd error, status=1 unexpected response from labview: ''
2016/06/10 18:02:46.815 medipixDetector:mpxReadCmd error, status=1 unexpected response from labview: ''
2016/06/10 18:02:47.155 medipixDetector:mpxReadCmd error, status=0 unexpected response from labview: 'MPX,0000000022,CMD,STOPACQUISITION,0'
2016/06/10 18:02:47.162 medipixDetector:mpxReadCmd error, status=0 unexpected response from labview: 'MPX,0000000022,SET,OPERATINGENERGY,0'
2016/06/10 18:02:47.166 medipixDetector:mpxReadCmd error, status=0 unexpected response from labview: 'MPX,0000000017,SET,THRESHOLD0,0'
2016/06/10 18:02:47.169 medipixDetector:mpxReadCmd error, status=0 unexpected response from labview: 'MPX,0000000027,GET,THRESHOLD0,10.000000,0'
2016/06/10 18:02:47.186 medipixDetector:writeFloat64 error, status=1 function=83, value=10.000000
2016/06/10 18:02:47.186 XF:10IDD-ES{Merlin:1}cam1:ThresholdEnergy0 devAsynFloat64 pPvt->result.status=1, process error
epics>
Kazimierz
RE: Merlin and AreaDetector giles.knap
Merlin and AreaDetector Gofron, Kazimierz
RE: Merlin and AreaDetector Mark Rivers
RE: Merlin and AreaDetector Gofron, Kazimierz
Prev: RE: Merlin and AreaDetector Gofron, Kazimierz
Next: Re: Error msg Stefen Paul
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Merlin and AreaDetector giles.knap
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
