1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Array record type in EPICS OPC device support
Date: Thu, 16 Jun 2016 08:14:38 +0000
Dear all,
I'm evaluating the EPICS OPC device support version 3.8.0.1 to read and
write data to a SIEMENS PLC (http://www-csr.bessy.de/control/SoftDist/O
PCsupport/).
Reading the documentation that can be found here:
http://www-csr.bessy.de/control/SoftDist/OPCsupport/download/readme3.8.
0.1.html#cont_14
It seems that array record types (i.e. aai, aao) are not supported (but
are mentioned in "opcDbg: OPC browsing and debugging" section).
Looking at source code (devOpc.c @ row 63) instead it seems that aai
and aao are both supported.
Which is the status of the EPICS OPC device support? Are array records
supported?
Thanks for your help.
Cheers,
Luca
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
Prev: the problem about the driver package s7plc.tgz 许婕
Next: Re: Problem in base 3.15.x at runtime Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: MCA under windows7 64-bit Hinxx
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
