I'm trying to get MCA R4-4 extension built under Windows7, 64-bit, for
Matlab 2016a. I'm using Microsoft Windows SDK v7.1 and set of compilers
that SDK provides (VS2010?).
EPICS base compilation goes nicely through, using windows-x64 target.
Compiler reports:
c:\MATLAB\R2016a\toolbox\mca>cl
Microsoft (R) C/C++ Optimizing Compiler Version 16.00.30319.01 for x64
Copyright (C) Microsoft Corporation. All rights reserved.
MCA compile line taken from one of the alt_compile files in mca.
c:\MATLAB\R2016a\toolbox\mca>mex mca.cpp MCAError.cpp Channel.cpp
c:\base-3.14.12.5\lib\windows-x64\Com.lib
c:\base-3.14.12.5\lib\windows-x64\ca.lib -DDB_TEXT_
LBLSOURCE -DMSCC -DEPICS_DLL_NO -DWIN64 -Ic:\base-3.14.12.5\include
-Ic:\base-3.14.12.5\include\os\WIN32 -v -DWIN32
[... lots of cruft that I can post if needed ...]
I'm seeing this problem when linking:
link /nologo /manifest /DLL /EXPORT:mexFunction
C:\Users\dummy\AppData\Local\Temp\mex_162312581152441_3188\mca.obj
2581152441_3188\MCAError.obj
C:\Users\dummy\AppData\Local\Temp\mex_162312581152441_3188\Channel.obj
c:\base-3.14.12.5\lib\windows-x64\Com.lib c:\base-3.14.12.
/LIBPATH:"C:\MATLAB\R2016a\extern\lib\win64\microsoft" libmx.lib
libmex.lib libmat.lib kernel32.lib user32.lib gdi32.lib winspool.lib
omdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib
odbc32.lib odbccp32.lib /out:mca.mexw64
Creating library mca.lib and object mca.exp
Channel.obj : error LNK2019: unresolved external symbol dbr_value_size
referenced in function "private: void __cdecl
Channel::AllocChanMem(void)" (?AllocChanMe
@Channel@@AEAAXXZ)
Channel.obj : error LNK2019: unresolved external symbol dbr_size
Channel::AllocChanMem(void)" (?AllocChanMem@Chan
el@@AEAAXXZ)
Channel.obj : error LNK2019: unresolved external symbol dbf_text_dim
hannel@@AEAAXXZ)
mca.mexw64 : fatal error LNK1120: 3 unresolved externals
Looking a bit into ca access.cpp source, epicsShareDef is used for
dbr_value_size, dbr_size and dbf_text_dim.
Am I hitting shared vs. static build issue?
I'm also not sure if the -DWIN32 is adequate in MCA compile line - I
want 64-bit mca mex object.
Any pointers welcomed.
Hinko
- RE: MCA under windows7 64-bit Mark Rivers
- Re: MCA under windows7 64-bit Andrew Johnson
Re: Problem in base 3.15.x at runtime Michael Davidsaver
<2016>
Array record type in EPICS OPC device support Luca Cavalli
<2016>
