You can get it to compile with gcc 6.1 if you edit
epicsExceptionTest.cpp and remove the "const" from the line:
static const size_t unsuccessfulNewSize = numeric_limits < size_t > :: max ();
There is a change committed to the for the next release, but it checks
the version of gcc. It probably should check which -std option was given
instead.
--Bob Soliday
On 06/28/2016 04:00 AM, Luca Cavalli wrote:
Dear all,
on my office laptop I'm running Fedora 24, which comes with GCC 6 by
default.
It seems that compiling EPICS 3.14.12.5 with GCC 6 fails here:
/usr/bin/g++ -c -D_GNU_SOURCE -D_DEFAULT_SOURCE -
D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -m64 -MMD -I.
-I../O.Common -I. -I.. -I../../../../include/os/Linux
-I../../../../include ../epicsExceptionTest.cpp
../epicsExceptionTest.cpp: In function ‘void
epicsExceptionTestPrivate()’:
../epicsExceptionTest.cpp:68:49: error: size of array is too large
char * p = new char [unsuccessfulNewSize];
../epicsExceptionTest.cpp:79:38: error: size of array is too large
../../../../configure/RULES_BUILD:218: recipe for target
'epicsExceptionTest.o' failed
GCC 6 defaults to -std=gnu++14 instead of -std=gnu++98 [1]. Adding this
option to compiler command seems to fix the problem, but which is the
best place to set the desired standard?
I tried in config/CONFIG_COMMON modifying:
POSIX_CPPFLAGS += $(POSIX_CPPFLAGS_$(POSIX)) -std=gnu++98
or:
USR_CXXFLAGS = -std=gnu++98
but the option seems to be ignored.
Thanks for your help.
Cheers,
Luca
[1] - https://gcc.gnu.org/gcc-6/porting_to.html#gxx14
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
- RE: Compiling EPICS 3.14.12.5 with GCC 6 Hill, Jeff
- Compiling EPICS 3.14.12.5 with GCC 6 Luca Cavalli
AW: bit shifting operators info22
RE: Call to assert failed - EPICS Pedro Mantovani Antunes
<2016>
<2016>
