> I¹m getting complaints about identical PV¹s being found on multiple
> servers, but I think this is a side effect of running on a VM.
You will also get that complaint if you run the server and client on the same machine, and if the machine has more than 1 network card. You can eliminate the complaint by setting EPICS_CA_AUTO_ADDR_LIST=NO and EPICS_CA_ADDR_LIST=xxx.yyy.zzz.255 where xxx.yyy.zzz.255 is the broadcast address of the subnet you want to use for Channel Access.
From: [email protected] [[email protected]] on behalf of Stephen Molloy [[email protected]]
Sent: Monday, July 04, 2016 4:09 PM
To: Ralph Lange; EPICS Tech-Talk
Subject: Re: Post numbers used by CA client
Thanks Ralph,
Your comment on UDP & TCP was the clue I needed. I had opened 5064 &
5065, but only for TCP connections. Opening them up for UDP as well
allowed external connections. Using the following command to run the
docker container did the trick,
docker run -i -t ‹rm -p 5064:5064 -p 5064:5064/udp -p 5065:5065 -p
5065:5065/udp sdmolloy/ubuntu-playground:latest /bin/bash
Thanks for your help,
Steve
On 04/07/16 17:02, "Ralph Lange" <[email protected]> wrote:
>Hi Steve,
>A CA client uses ephemeral ports as originating port numbers, correct.
>Ephemeral port numbers are indeed random, and cannot be predicted
>reliably.
>However, if your container contains an IOC (CA server), opening ports
>5064&5065 (in the default setup) for both TCP and UDP should allow any
>client outside the container to connect. (Not much different to a
>container with a web service published at port 80.)
>The CA client in the container would still use ephemeral port numbers
>for outgoing connections - do you need to publish those?
>Cheers,
>~Ralph
>On 04/07/2016 16:43, Stephen Molloy wrote:
>> I¹m trying to build a Docker container for quick set-up and tear-down
>> of EPICS instances, and I¹ve run into a problem. A CA client outside
>> the container, but on the same host, cannot see any PV¹s served from
>> inside the container.
>> Looking at the network traffic with Wireshark, I can see that the
>> server uses ports 5064 & 5065 as expected, but the ports used by the
>> client seem to be relatively random. If I could predict them, or
>> (even better) force them to be specific ports, then I could expose
>> those ports in the Docker container and (hopefully) the client and
>> server could communicate properly.
>> Or perhaps this isn¹t the problem, and there is some other network
>> issue getting in my way.
>> (I¹ve successfully run several EPICS installations on this network and
>> from this computer, so I am confident that this is an issue with the
>> Docker set-up.)
>> Hopefully I¹m on the right track with my thinking, and hopefully
>> someone can let me know how to proceed from here?
>> In case you¹re interested, I¹m documenting my work on my blog ‹
>> http://www.smolloy.com/2016/07/easy-epics-implementation-with-docker/
>> Thanks (again) for your time,
>> Steve
- Post numbers used by CA client Stephen Molloy
- Re: Post numbers used by CA client Ralph Lange
- Re: Post numbers used by CA client Stephen Molloy
MRF EVG, EVR, and EVM's Linux Kernel modules Jeong Han Lee
<2016>
Re: Post numbers used by CA client Andrew Johnson
<2016>
