1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to configurate MCA for Octave
To: Eric Norum <[email protected]>, [email protected]
Date: Thu, 21 Jul 2016 20:45:38 +0300
Thank you so much sir.. I built it successfully..
The things that i made wrong are :
1) I couldn't set up environment variables ,EPICS_EXTENSIONS,EPICS_BASE,EPICS_HOST_ARCH.. But,they're done..
2) Once the enviironment variables are set up in the extension's folder,which is "/opt/epics/extensions/src/mca" for me, I run the "buildForOctave.sh" file at the same direction. But i had the same error..
3) So I checked the octave shell path, I didn't install the "liboctave-dev" library . Then I installed it and made the same steps. In conclusion, all the things for building MCA for Octave worked fine..
All of things that I've done are thanks to you,sir..
Best Wishes for you..
Best Regards..
Hulusi
2016-07-21 20:34 GMT+03:00 Eric Norum <[email protected]>:
Please post a note to Tech-Talk as well announcing that you have this working.  This will help others following in your footsteps to know that you managed to succeed.
On Jul 21, 2016, at 10:32 AM, Hulusi Öz <[email protected]> wrote:
Sir, how much i thank to you that won't be enough.. It's done.. I am sorry for taking your time.. I am new at either linux platfor or EPICS..
Eric Norum
[email protected]
Re: How to configurate MCA for Octave Hulusi Öz
Re: How to configurate MCA for Octave Eric Norum
Prev: Re: How to configurate MCA for Octave Eric Norum
Next: RE: EpicsQT and Archiver Appliance Andrew C. Starritt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: How to configurate MCA for Octave Hulusi Öz
ANJ, 22 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
