> For readIt(), the driver returns the length of the payload,
No, that is not true. This is from asynPortDriver::readOctet
*nActual = strlen(value)+1;
So it returns the length including the nil byte.
This change was made after much tech-talk discussion in asyn R4-21:
Sent: Saturday, July 23, 2016 5:34 PM
To: Mark Rivers; 'Eric Norum'; Andrew Johnson
Cc: [email protected] list
Subject: Re: Inconsistency in devAsynOctet for stringout and waveform records
How should the interface to the driver be ?
and asyn adds 1 for the terminating NUL before going out to the rest of
EPICS.
(Please correct me, if this is wrong)
For writeIt(), I would prefer to use the same principle,
and use the length of the payload, 3 in our case.
This would be in line with what the unix read() and write() functions do,
and, what I understand, the asyn-record does.
And, would need changes for the waveform record.
How many things would this change break ?
On 07/22/2016 10:55 PM, Mark Rivers wrote:
> Hi Eric and Andrew (and others),
> I have just found an inconsistency in the devAsynOctet.c for handling
> string output for stringout records versus waveform records.
> I have a stringout record which I process as follows:
> caput SIM1:SOHigh "abc"
> This is the output of devAsynOctet.c with some debugging statements added:
> devAsynOctet::callbackSoWrite, calling writeIt with message="abc",
> nbytes=3
> This is what happens when I write the same string with a waveform record:
> caput -S SIM1:WFOutHigh "abc"
> devAsynOctet::callbackWfWrite, calling writeIt with message="abc",
> nbytes=4
> So in the case of the stringout record the length being passed to the
> driver is strlen() of the string, while for the waveform record it is
> the NORD field of the waveform record. NORD includes the terminating
> 0 byte.
> This difference in behavior is causing me problems when extending the
> Modbus driver to handle strings.
> Which do you feel is the “correct” behavior? Should the driver be
> called with nbytes including the trailing 0 or not?
> You may recall that in asyn R4-21 we made the following change (from
> the release notes):
> “Changed the code so that the length of string parameters returned in
> readOctet and octetCallback is now strlen(string)+1, rather than
> strlen(string). The length thus now includes the terminating nil. This
> fixes problems with clients that request long strings or subscribe to
> monitors with a length of 0, but don't check for a nil terminator.”
> So we do include the terminating nil in the length for readOctet. For
> consistency it seems like the nil should be included in the length
> passed to the driver from writeOctet. This means the stringout record
> support is the one that needs to be changed.
> Mark
- RE: Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
- Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
- Re: Inconsistency in devAsynOctet for stringout and waveform records Torsten Bögershausen
Re: Inconsistency in devAsynOctet for stringout and waveform records Eric Norum
<2016>
<2016>
