1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Inconsistency in devAsynOctet for stringout and waveform records
To: Eric Norum <[email protected]>
Cc: "[email protected] list" <[email protected]>
Date: Sat, 23 Jul 2016 23:29:04 +0000
The problem is that then all asyn port drivers that are expecting to receive strings need to handle two different cases, one where the length being passed includes the nil, and one where it does not.  When the user changes from a stringout to a waveform record because their string just exceeded 40 characters, the driver receives something fundamentally different.
Is this what we want?
I am not proposing that we change the ability of the waveform record to handle arbitrary data, because I am not changing the behavior for the waveform record.  I am proposing changing the behavior of the stringout record to match the waveform record.
Sent: Saturday, July 23, 2016 6:21 PM
To: Mark Rivers
Cc: [email protected] list
Subject: Re: Inconsistency in devAsynOctet for stringout and waveform records
So the device at the other end of the wire will see ‘\0’ characters?  That doesn’t seem right to me.
I think that the existing behaviour is correct.  stringout records send strings — and no trailing ‘\0’.  waveform records send blocks of arbitrary bytes.
On Jul 23, 2016, at 4:11 PM, Mark Rivers <[email protected]<redir.aspx?REF=vQWMibMa4aKg9zRQSmd-ru4UccacVDJ4hzXfNTBOjuhdxhxnULPTCAFtYWlsdG86cml2ZXJzQGNhcnMudWNoaWNhZ28uZWR1>> wrote:
So writing a string to a waveform record with Channel Access or dbpf also sets NORD to include the nil byte.
So my conclusion is that the stringout behavior in devAsynOctet is incorrect, it is not including the nil byte in the call to writeIt, but it should be.
Re: Inconsistency in devAsynOctet for stringout and waveform records Eric Norum
Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
RE: Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
Prev: RE: Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
Next: Re: Inconsistency in devAsynOctet for stringout and waveform records Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Inconsistency in devAsynOctet for stringout and waveform records Eric Norum
ANJ, 23 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
