1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EpicsQT and Archiver Appliance
To: [email protected]
Cc: [email protected]
Date: Thu, 28 Jul 2016 10:57:19 -0400
On 07/28/2016 08:23 AM, [email protected] wrote:
> Command: info
> Error
> Traceback (most recent call last):
>   File "/usr/local/bin/arinfo", line 215, in main
>     yield haveArchive(*args)
> KeyError: 'Section test.conf has no key urltype'
oops, that's because I gave you a broken example...
> cat <<EOF > carchive.conf
> [DEFAULT]
> urltype = appl
> host = http://localhost:17665/mgmt/bpl/getApplianceInfo
> EOF
> arinfo -vvv -a '*'
This will find 'carchive.conf' in the current directory.  It will also
look in ~/.carchiverc and /etc/carchive.conf.  The -C/--conf option
specifies a config file section.  This allows one file with
configuration for multiple archivers.
Re: EpicsQT and Archiver Appliance rory.clarke
Re: EpicsQT and Archiver Appliance Michael Davidsaver
RE: EpicsQT and Archiver Appliance rory.clarke
Prev: Re: Epics-Digitizer Communication Eric Norum
Next: NDArrayPool::alloc failing Phil Atkin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EpicsQT and Archiver Appliance rory.clarke
Next: Problem with procServ on RHEL6 Mark Rivers
ANJ, 28 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
