1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: may I start a pcaspy ioc together with a streamdevice ioc?
To: [email protected]
Date: Thu, 28 Jul 2016 10:20:26 -0700
If this is using Linux-GPIB as the underlying asyn port driver, then there is apparently a long standing bug that causes waveform records to transfer very slowly with streamDevice. My workaround for this was to use a waveform record with asynOctetCmdResponse DTYP (thanks to either Eric or Mark for suggesting that) for that one operation. I post-process the octet data using a subroutine record and it works fine. The OP's problem seems to be a bit more complicated, as the array needs to be sent, rather than received, but if the cause of the problem is a match, at least the solution may be closer at hand.
Rod Nussbaumer,
TRIUMF,
Vancouver, Canada
On 07/25/2016 04:45 AM, Mark Rivers wrote:
Why is StreamDevice slow to transfer the data?  I don't think that should be the case, StreamDevice should be able to go as fast as any other software.  I think the simplest solution would be to figure out why StreamDevice is slow for you.
From: [email protected] [[email protected]] on behalf of Silver [[email protected]]
Sent: Monday, July 25, 2016 6:34 AM
To: tech-talk
Subject: may I start a pcaspy ioc together with a streamdevice ioc?
hi, all
   I have a normal streamdevice ioc which controls power supply via ethernet. Now I want to add a function to send large waveform data (about 10000 floats) to power supply. If I just use streamdevice to transfer the data, the speed is slow and can't satisfy my requriement.
   I with to use pcaspy to creat another ioc as it can supply a pv to a client, for example, which inform to send data by a pv write, then the pcaspy ioc will send the data to power supply by ethernet. so I have two questions:
1. how to use the same socket of streamdevice? power supply controller has only one socket server. (during data transfer, I can stop the streamdevice db processing)
2. how to hook up the pcaspy ioc together with streamdevice ioc? (if I don't want to use procServ or inet, etc.)
   thanks a lot for your help.
Best wishes
Geyang 2016-07-25
RE: may I start a pcaspy ioc together with a streamdevice ioc? Mark Rivers
may I start a pcaspy ioc together with a streamdevice ioc? Silver
Prev: NDArrayPool::alloc failing Phil Atkin
Next: RE: may I start a pcaspy ioc together with a streamdevice ioc? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: may I start a pcaspy ioc together with a streamdevice ioc? Mark Rivers
ANJ, 28 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
