1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA connection problems between VxWorks and Windows
To: [email protected]
Date: Fri, 5 Aug 2016 13:38:19 -0400
On 08/05/2016 11:23 AM, Benjamin Franksen wrote:
> Now, if we change the IP address on the windows PC to another free
> address in the network, channel access first works. Everything is fine
> but only for 3 to 5 minutes. Then connections to the vxWorks IOC fail
> again. Setting the IP address to a third variant has the same effect.
> Everything works but only for a few minutes. Setting the IP address back
> to the original one still doesn't work. Deactivating and  re-activating
> the network interface doesn't help. After a while, maybe  15 to 30
> minutes, an IP address that didn't work and wasn't used for that time,
> can be used again, but still, only for 2 to 3 minutes.
What is the network topology like?  This behavior sounds like some
security system is blocking IPs based on "suspicious" traffic.
Re: CA connection problems between VxWorks and Windows Benjamin Franksen
Prev: CA connection problems between VxWorks and Windows Benjamin Franksen
Next: Error in interfacing gigE camera make: Balser avanish
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CA connection problems between VxWorks and Windows Benjamin Franksen
ANJ, 08 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
