1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Drawing on XY graph widget without the use of a PV in CSS
To: Abdalla Ahmad <[email protected]>
Cc: Márcio Paduan Donadio <[email protected]>, "[email protected] list" <[email protected]>
Date: Wed, 10 Aug 2016 13:48:21 +0000
Try this instead:
loc://x(0)
which will default it to zero.
Cheers,
Matt
> On Aug 10, 2016, at 3:51 AM, Abdalla Ahmad <[email protected]> wrote:
> How to use these variables loc://x and loc://y ? I added them as input PVs to the script but it gives me loc://x has a null value. Am I missing something?
> Best Regards,
> Abdalla Ahmad
> Control Engineer
> SESAME
> Allan, Jordan.
> Tel: (+962-5) 3511348 , ext. 265
> Fax: (+962-5) 3511423
> Mob: (+962-7)88183296
> www.sesame.org.jo
> From: [email protected] [mailto:[email protected]] On Behalf Of M?rcio Paduan Donadio
> Sent: Monday, August 08, 2016 3:38 PM
> To: [email protected]
>     You can use loc variables in X PV and Y PV parameters. Eg: loc://x and loc://y.
>     Inside the script you can do something like this:
> from java.util import Arrays
> from jarray import zeros
> from java.lang import Double
> x = zeros(NUM_OF_STEPS, Double)
> y = zeros(NUM_OF_STEPS, Double)
> for i in range (NUM_OF_STEPS):
>     x[i] = 0
>     y[i] = 0
> # Do processing....
> pvs[0].setValue(x)
> pvs[1].setValue(y)
> Engenheiro de Computação - Software de Operação das Linhas de Luz
> Laboratório Nacional de Luz Síncrotron – (LNLS)
> Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
> + 55 (19) 3512-3520 - [email protected]
> www.lnls.cnpem.br
> Hello
> Is it possible to draw some data on an XY graph widget from a script/rule without using a PV? I mainly tried setting the property 'pv_value' but nothing appears on the graph. I'm not sure if this is even possible or not. The thing is I will receive a waveform PV value and I want to do some processing on it then displaying the output on the XY graph.
> Best Regards,
> Abdalla.
Re: Drawing on XY graph widget without the use of a PV in CSS Kasemir, Kay
Re: Drawing on XY graph widget without the use of a PV in CSS Márcio Paduan Donadio
RE: Drawing on XY graph widget without the use of a PV in CSS Abdalla Ahmad
Prev: RE: Drawing on XY graph widget without the use of a PV in CSS Abdalla Ahmad
Next: Re: Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Drawing on XY graph widget without the use of a PV in CSS Kasemir, Kay
ANJ, 10 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
