1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Drawing on XY graph widget without the use of a PV in CSS
To: "Pearson, Matthew R." <[email protected]>, Abdalla Ahmad <[email protected]>
Cc: Márcio Paduan Donadio <[email protected]>, "[email protected] list" <[email protected]>
Date: Wed, 10 Aug 2016 14:22:53 +0000
Hi:
There's some history behind local variables that goes back to EDM.
When you use a variable
  loc://x
then there is of course the question of initial value.
I think EDM used zero, and way back CSS also used 0 as the initial value.
... but we wanted to allow initialization of local variables with something other than zero, and also to allow local variables that hold strings (and later enums etc.).
So we supported
  loc://x(42.3)
  loc://y("Fred (Pete) Hammersmith, Jr.")
That brought up the question:
What if you open one display that uses
  loc://x(42.3)
and another that uses
  loc://x(3.14)
at the same time?
What will be the initial value of that local PV?
Should whatever runs first initialize the PV, and whatever happens next then leaves the value as found, because it's already initialized? That's what EDM and the first CSS utility.pv did.
The PVManager decided to throw an exception if you used the same variable with different initializer values, because you can't really predict what runs first, so you better make all initializers match.
The vtype.pv considers them different variables, i.e. loc://x(42.3) == 42.3 and loc://x(3.14) == 3.14 and they're different variables, writing to loc://x(42.3) will not change loc://x(3.14) and vice versa.
If you use local variables, either use "loc://x" and beware that the initial value is null, so you need to somehow set it.
Or use "loc://x(42.3)" and assert that you always use the PV exactly like that, considering "loc://x(42.3)" with that initializer to be the full name of the PV, because that way it will behave the same way in all the tools & versions.
-Kay
From: [email protected] <[email protected]> on behalf of Pearson, Matthew R. <[email protected]>
Sent: Wednesday, August 10, 2016 9:48 AM
To: Abdalla Ahmad
Cc: Márcio Paduan Donadio; [email protected] list
Subject: [EXTERNAL] Re: Drawing on XY graph widget without the use of a PV in CSS
Try this instead:
loc://x(0)
which will default it to zero.
Cheers,
Matt
> On Aug 10, 2016, at 3:51 AM, Abdalla Ahmad <[email protected]> wrote:
> How to use these variables loc://x and loc://y ? I added them as input PVs to the script but it gives me loc://x has a null value. Am I missing something?
> Best Regards,
> Abdalla Ahmad
> Control Engineer
> SESAME
> Allan, Jordan.
> Tel: (+962-5) 3511348 , ext. 265
> Fax: (+962-5) 3511423
> Mob: (+962-7)88183296
> www.sesame.org.jo
> From: [email protected] [mailto:[email protected]] On Behalf Of M?rcio Paduan Donadio
> Sent: Monday, August 08, 2016 3:38 PM
> To: [email protected]
>     You can use loc variables in X PV and Y PV parameters. Eg: loc://x and loc://y.
>     Inside the script you can do something like this:
> from java.util import Arrays
> from jarray import zeros
> from java.lang import Double
> x = zeros(NUM_OF_STEPS, Double)
> y = zeros(NUM_OF_STEPS, Double)
> for i in range (NUM_OF_STEPS):
>     x[i] = 0
>     y[i] = 0
> # Do processing....
> pvs[0].setValue(x)
> pvs[1].setValue(y)
> Engenheiro de Computação - Software de Operação das Linhas de Luz
> Laboratório Nacional de Luz Síncrotron – (LNLS)
> Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
> + 55 (19) 3512-3520 - [email protected]
> www.lnls.cnpem.br
> Hello
> Is it possible to draw some data on an XY graph widget from a script/rule without using a PV? I mainly tried setting the property 'pv_value' but nothing appears on the graph. I'm not sure if this is even possible or not. The thing is I will receive a waveform PV value and I want to do some processing on it then displaying the output on the XY graph.
> Best Regards,
> Abdalla.
RE: Drawing on XY graph widget without the use of a PV in CSS Abdalla Ahmad
Re: Drawing on XY graph widget without the use of a PV in CSS Márcio Paduan Donadio
Re: Drawing on XY graph widget without the use of a PV in CSS Pearson, Matthew R.
Prev: Re: Shen, Guobao
Next: Re: Query Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Drawing on XY graph widget without the use of a PV in CSS Pearson, Matthew R.
Next: RE: Drawing on XY graph widget without the use of a PV in CSS Abdalla Ahmad
ANJ, 14 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
