1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EGU field length vs. Channel Access protocol
To: "Vodopivec, Klemen" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 11 Aug 2016 15:58:10 +0000
Hi:
Klemen found that the EGU field for ai is STRING[16] and he can set an EGU field accordingly:
$ caput BL11A:Det:crocD2:Y1:RateTrigger.EGU "abcdefghijklmnop"
Old : BL11A:Det:crocD2:Y1:RateTrigger.EGU 123456789012345
New : BL11A:Det:crocD2:Y1:RateTrigger.EGU abcdefghijklmno
The channel access protocol, however, only gives us a MAX_UNITS_SIZE of 8 in db_access.h:
 #define MAX_UNITS_SIZE          8
 /* structure for a control double field */
struct dbr_ctrl_double{
        dbr_short_t     status;                 /* status of value */
        dbr_short_t     severity;               /* severity of alarm */
        dbr_short_t     precision;              /* number of decimal places */
        dbr_short_t     RISC_pad0;              /* RISC alignment */
        char            units[MAX_UNITS_SIZE];  /* units of value */
        dbr_double_t    upper_disp_limit;       /* upper limit of graph */
        dbr_double_t    lower_disp_limit;       /* lower limit of graph */
        dbr_double_t    upper_alarm_limit;
        dbr_double_t    upper_warning_limit;
        dbr_double_t    lower_warning_limit;
        dbr_double_t    lower_alarm_limit;
        dbr_double_t    upper_ctrl_limit;       /* upper control limit */
        dbr_double_t    lower_ctrl_limit;       /* lower control limit */
        dbr_double_t    value;                  /* current value */
Does anybody remember the reasoning for this?
Would it make sense to shorten the EGU field length in records?
Or lengthen MAX_UNITS_SIZE?
Or was this done in anticipation of 2-byte characters for units ;-) ?
-Kay
Re: EGU field length vs. Channel Access protocol bob dalesio
Re: EGU field length vs. Channel Access protocol Andrew Johnson
Prev: Questions about Data browser in CSS lzf neu
Next: Re: Questions about Data browser in CSS Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Questions about Data browser in CSS Kasemir, Kay
Next: Re: EGU field length vs. Channel Access protocol bob dalesio
ANJ, 11 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
