1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EGU field length vs. Channel Access protocol
To: <[email protected]>
Date: Thu, 11 Aug 2016 12:14:14 -0500
Hello Kay,
On 08/11/2016 10:58 AM, Kasemir, Kay wrote:
> Klemen found that the EGU field for ai is STRING[16] and he can set an EGU field accordingly:
> $ caput BL11A:Det:crocD2:Y1:RateTrigger.EGU "abcdefghijklmnop"
> Old : BL11A:Det:crocD2:Y1:RateTrigger.EGU 123456789012345
> New : BL11A:Det:crocD2:Y1:RateTrigger.EGU abcdefghijklmno
> The channel access protocol, however, only gives us a MAX_UNITS_SIZE of 8 in db_access.h:
>  #define MAX_UNITS_SIZE          8
>  /* structure for a control double field */
> struct dbr_ctrl_double{
>         char            units[MAX_UNITS_SIZE];  /* units of value */
> Does anybody remember the reasoning for this?
Old-style db_access (i.e. CA structures) vs newer dbAccess (internal IOC
API with better flexibility). From the newer dbAccessDefs.h:
> #define DB_UNITS_SIZE   16
> #define DBRunits \
> 	char		units[DB_UNITS_SIZE];	/* units	*/
This is similar to the issue that by using the dbAccess API the IOC can
handle enums with up to 30 choices and choice strings (DB_MAX_CHOICES
defined in dbDefs.h), but CA never switched to the new API and can only
transport 16 choice strings, so it can't transport all the STAT menu
strings for example.
> Would it make sense to shorten the EGU field length in records?
I would rather leave it at 16, since we now have pvAccess which *can*
access and transport the wider string.
> Or lengthen MAX_UNITS_SIZE?
That would require changes to the on-the-wire CA protocol and could
break CA client applications.
- Andrew
EGU field length vs. Channel Access protocol Kasemir, Kay
Prev: Re: EPICS 3.15 good for production use? J. Lewis Muir
Next: Race condition in db_get_field_and_count() (3.14.12) Williams Jr., Ernest L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EGU field length vs. Channel Access protocol bob dalesio
Next: Streamdevice for Hexa command "최숙"
ANJ, 11 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
