1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: wait/dealy inside a record
To: [email protected]
Date: Fri, 12 Aug 2016 09:59:55 -0400
On 08/12/2016 03:48 AM, Stefen Paul wrote:
> Hi all,
> I'm using a waveform record (with custom device support) for writing &
> reading a hardware.
> I need following sequence:
> - write to a register
> - wait for 20 microseconds
> - again write to the same register
> - again wait for 20 microseconds
> - read an array of other registers
> Any tips on how can I generate a delay/wait of ~20 microsec inside the
> device support routine  or otherwise in EPICS ?
A simple example of asynchronous device support.
http://mdavidsaver.github.io/epics-doc/epics-devsup.html#_asynchronous_example
wait/dealy inside a record Stefen Paul
Prev: wait/dealy inside a record Stefen Paul
Next: Question about pv value and the label display in CSS boy opi lzf neu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: wait/dealy inside a record Andrew Johnson
ANJ, 12 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
