1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: installation of synapps_5_8 in ubuntu
Date: Tue, 16 Aug 2016 12:41:46 +0000
I am not sure what the problem is.
You could try:
- Upgrading to latest version of autosave
github.com/epics-modules/autosave
Or go back to EPICS base 3.14.12.5 which is what synApps_5_8 is normally used with.
Sent: Tuesday, August 16, 2016 6:37 AM
To: Mark Rivers
Cc: [email protected]; [email protected]
Here are the complete output from the autosave directory
avanish@avanish-dell:/opt/epics/synApps_5_8/support/autosave-5-6-1$ make
clean uninstall
make -C ./configure clean
make[1]: Entering directory
'/opt/epics/synApps_5_8/support/autosave-5-6-1/configure'
rm -rf O.linux-x86 O.Common
make[1]: Leaving directory
make -C ./asApp clean
'/opt/epics/synApps_5_8/support/autosave-5-6-1/asApp'
make -C ./src clean
make[2]: Entering directory
'/opt/epics/synApps_5_8/support/autosave-5-6-1/asApp/src'
make[2]: Leaving directory
make -C ./Db clean
'/opt/epics/synApps_5_8/support/autosave-5-6-1/asApp/Db'
make -C ./iocBoot clean
'/opt/epics/synApps_5_8/support/autosave-5-6-1/iocBoot'
make -C ./iocas clean
'/opt/epics/synApps_5_8/support/autosave-5-6-1/iocBoot/iocas'
rm -f cdCommands envPaths dllPath.bat relPaths.sh
rm -rf ./bin/linux-x86
rm -rf ./lib/linux-x86
rm -rf ./dbd ./include ./doc ./html ./templates ./db ./adl ./alh ./cfg
./edl ./lib/perl ./lib/pkgconfig
make -C ./configure install
perl -CSD /opt/epics/base-3.15.3/bin/linux-x86/makeMakefile.pl O.linux-x86
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. \
    T_A=linux-x86 install
'/opt/epics/synApps_5_8/support/autosave-5-6-1/configure/O.linux-x86'
perl -CSD /opt/epics/base-3.15.3/bin/linux-x86/convertRelease.pl checkRelease
make -C ./asApp install
make -C ./src install
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory
'/opt/epics/synApps_5_8/support/autosave-5-6-1/asApp/src/O.linux-x86'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX
-Dlinux     -O3 -g   -Wall      -mtune=generic     -m32
-D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I../os/Linux
-I../os/default -I.. -I../../../include/compiler/gcc
-I../../../include/os/Linux -I../../../include
-I/opt/epics/base-3.15.3/include/compiler/gcc
-I/opt/epics/base-3.15.3/include/os/Linux -I/opt/epics/base-3.15.3/include
       -MM -MF osdNfs.d  ../os/Linux/osdNfs.c
       -MM -MF verify.d  ../verify.c
       -MM -MF configMenuSub.d  ../configMenuSub.c
       -MM -MF fGetDateStr.d  ../fGetDateStr.c
       -MM -MF initHooks.d  ../initHooks.c
       -MM -MF save_restore.d  ../save_restore.c
       -MM -MF dbrestore.d  ../dbrestore.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX
-D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I../os/Linux
       -MM -MF asMain.d  ../asMain.cpp
Expanding dbd file ../asInclude.dbd
perl -CSD /opt/epics/base-3.15.3/bin/linux-x86/dbdExpand.pl   -I. -I..
-I../O.Common -I../../../dbd -I/opt/epics/base-3.15.3/dbd -o as.dbd
../asInclude.dbd
perl -CSD
/opt/epics/base-3.15.3/bin/linux-x86/registerRecordDeviceDriver.pl   -I.
-I.. -I../O.Common -I../../../dbd -I/opt/epics/base-3.15.3/dbd    -o
as_registerRecordDeviceDriver.cpp ../O.Common/as.dbd
       -MM -MF as_registerRecordDeviceDriver.d
       -MM -MF asVerify.d  ../asVerify.c
Installing created dbd file ../../../dbd/as.dbd
mkdir ../../../dbd
Installing dbd file ../../../dbd/asSupport.dbd
Installing OS dependent include file ../../../include/os/Linux/osdNfs.h
mkdir ../../../include
mkdir ../../../include/os
mkdir ../../../include/os/Linux
       -c ../dbrestore.c
../dbrestore.c:1597:13: warning: ‘myDbLoadRecordsHook’ defined but not
used [-Wunused-function]
 static void myDbLoadRecordsHook(const char* fname, const char* macro) {
../dbrestore.c: In function ‘reboot_restore’:
../dbrestore.c:888:2: warning: ignoring return value of ‘fgets’, declared
with attribute warn_unused_result [-Wunused-result]
  (void)fgets(buffer, BUF_SIZE, inp_fd); /* discard header line */
../dbrestore.c: In function ‘checkFile’:
../dbrestore.c:1186:2: warning: ignoring return value of ‘fgets’, declared
  fgets(tmpstr, 29, inp_fd);
../dbrestore.c:1210:2: warning: ignoring return value of ‘fgets’, declared
  fgets(tmpstr, 6, inp_fd);
../dbrestore.c:1220:2: warning: ignoring return value of ‘fgets’, declared
  fgets(tmpstr, 7, inp_fd);
       -c ../save_restore.c
../save_restore.c: In function ‘connect_list’:
../save_restore.c:1333:16: warning: format not a string literal and no
format arguments [-Wformat-security]
   errlogPrintf(SR_recentlyStr);
../save_restore.c: In function ‘do_manual_restore’:
../save_restore.c:3128:3: warning: ignoring return value of ‘fgets’,
declared with attribute warn_unused_result [-Wunused-result]
../save_restore.c:3186:39: warning: ignoring return value of ‘fgets’,
      while (bp[strlen(bp)-1] != '\n') fgets(buffer, BUF_SIZE, inp_fd);
       -c ../initHooks.c
In file included from ../initHooks.c:40:0:
../save_restore.h:42:13: warning: ‘SR_STATUS_STR’ defined but not used
[-Wunused-variable]
 static char SR_STATUS_STR[5][10] =
       -c ../fGetDateStr.c
       -c ../configMenuSub.c
       -c ../verify.c
In file included from ../verify.c:17:0:
[-Wunused-variable]
../verify.c: In function ‘do_asVerify’:
../verify.c:69:2: warning: ignoring return value of ‘fgets’, declared with
  fgets(s, 6, fp);
../verify.c:73:3: warning: ignoring return value of ‘fgets’, declared with
   fgets(s, 7, fp);
../verify.c:307:39: warning: ignoring return value of ‘fgets’, declared
      while (bp[strlen(bp)-1] != '\n') fgets(s, BUF_SIZE, fp);
       -c ../os/Linux/osdNfs.c
/usr/bin/ar -rc    libautosave.a        dbrestore.o save_restore.o
initHooks.o fGetDateStr.o configMenuSub.o verify.o osdNfs.o
/usr/bin/ranlib libautosave.a
/usr/bin/g++ -o libautosave.so -shared -fPIC -Wl,-hlibautosave.so
-L/opt/epics/base-3.15.3/lib/linux-x86
-Wl,-rpath,/opt/epics/base-3.15.3/lib/linux-x86           -rdynamic -m32
         dbrestore.o save_restore.o initHooks.o fGetDateStr.o
configMenuSub.o verify.o osdNfs.o    -ldbRecStd -ldbCore -lca -lCom
-lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86/libautosave.so
mkdir ../../../lib/linux-x86
Installing library ../../../lib/linux-x86/libautosave.a
       -c ../asVerify.c
In file included from ../asVerify.c:15:0:
[-Wunused-variable]
/usr/bin/g++ -o asVerify  -L/opt/epics/base-3.15.3/lib/linux-x86
         asVerify.o verify.o    -lca -lCom
asVerify.o: In function `main':
/opt/epics/synApps_5_8/support/autosave-5-6-1/asApp/src/O.linux-x86/../asVerify.c:85:
warning: the use of `tmpnam' is dangerous, better use `mkstemp'
       -c as_registerRecordDeviceDriver.cpp
as_registerRecordDeviceDriver.cpp:279:12: warning: ‘done’ defined but not
used [-Wunused-variable]
 static int done = Registration();
       -c ../asMain.cpp
/usr/bin/g++ -o asApp
-L/opt/epics/synApps_5_8/support/autosave-5-6-1/lib/linux-x86
-Wl,-rpath,/opt/epics/synApps_5_8/support/autosave-5-6-1/lib/linux-x86
         as_registerRecordDeviceDriver.o asMain.o    -lautosave -ldbRecStd
-ldbCore -lca -lCom
/opt/epics/synApps_5_8/support/autosave-5-6-1/lib/linux-x86/libautosave.so:
undefined reference to `_dl_sysinfo'
collect2: error: ld returned 1 exit status
/opt/epics/base-3.15.3/configure/RULES_BUILD:192: recipe for target
'asApp' failed
make[3]: *** [asApp] Error 1
make[3]: Leaving directory
/opt/epics/base-3.15.3/configure/RULES_ARCHS:61: recipe for target
'install.linux-x86' failed
make[2]: *** [install.linux-x86] Error 2
/opt/epics/base-3.15.3/configure/RULES_DIRS:88: recipe for target
'src.install' failed
make[1]: *** [src.install] Error 2
'asApp.install' failed
make: *** [asApp.install] Error 2
Thank you
> ---------------------------- Original Message ----------------------------
> From:    "Mark Rivers" <[email protected]>
> Date:    Tue, August 16, 2016 4:47 pm
> You should send the complete output when you build in the autosave
> directory
> make clean uninstall
> make
> Mar
> From: [email protected] [[email protected]] on
> behalf of [email protected] [[email protected]]
> Sent: Tuesday, August 16, 2016 6:11 AM
> To: [email protected]
> Subject: installation of synapps_5_8 in ubuntu
> Hi,
>   I have copied synapps_5_8 under '/opt/epics'.
> epics-base is already build under /opt/epics/base-3.15.3
> msi is under /opt/epics/extensions/src/msi1.7
> When I am trying to build synapps with areaDetector by using 'make'
> command
> I am getting following errors.
> undefined reference to `__syscall_error'
> I am new to linux and could not get any suggestions from google.
> Please help me
> Thank you.
installation of synapps_5_8 in ubuntu avanish
RE: installation of synapps_5_8 in ubuntu Mark Rivers
RE: installation of synapps_5_8 in ubuntu avanish
Prev: RE: installation of synapps_5_8 in ubuntu avanish
Next: Variable SCAN Intervall and Roundoff function info22
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: installation of synapps_5_8 in ubuntu Benjamin Franksen
ANJ, 16 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
