1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: installation of synapps_5_8 in ubuntu
To: <[email protected]>, <[email protected]>
Date: Tue, 16 Aug 2016 17:17:20 +0200
On 16.08.2016 13:11, [email protected] wrote:
>   I have copied synapps_5_8 under '/opt/epics'.
> epics-base is already build under /opt/epics/base-3.15.3
> msi is under /opt/epics/extensions/src/msi1.7
> When I am trying to build synapps with areaDetector by using 'make' command
> I am getting following errors.
> /opt/epics/synApps_5_8/support/autosave-5-6-1/lib/linux-x86/libautosave.so:
> undefined reference to `_dl_sysinfo'
> undefined reference to `__syscall_error'
> collect2: error: ld returned 1 exit status
I could not reproduce this on my 32 bit ubuntu (14.04 LTS) machine.
However, googling for the error message led me to this
https://forums.gentoo.org/viewtopic-t-1032988-start-0.html
with a further link to
https://forums.gentoo.org/viewtopic-p-7725930.html
which suggest your problem could be due to "hardened" glibc and/or tool
chain (gcc, ld). It would perhaps be a good idea to completely re-build
EPICS base (make -sj distclean && make -sj) and then try again with
autosave. Also make sure you have no (ubuntu package) updates pending,
especially ones concerning the tool chain (gcc, glibc).
If that doesn't help, you could ask ubuntu support forums.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
installation of synapps_5_8 in ubuntu avanish
Prev: Variable SCAN Intervall and Roundoff function info22
Next: Re: Variable SCAN Intervall and Roundoff function Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: installation of synapps_5_8 in ubuntu Mark Rivers
Next: Variable SCAN Intervall and Roundoff function info22
ANJ, 16 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
