1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OS X edm/medm openmotif woes
To: Eric Norum <[email protected]>
Date: Fri, 26 Aug 2016 10:33:50 -0500
Hi Eric,
I was about to let you know sort of a bad news.  I found nothing interesting on my old computer, so I decided to try installing MEDM on one of my lab iMacs.  Well, unfortunately, I get the same problem as you do.  So clearly, back in November/December, I must have made some small adjustment somewhere to get MEDM working on El Capitan with OpenMotif.
I will play with it more and let you know, once I have something…
On Aug 26, 2016, at 10:31 AM, Eric Norum <[email protected]> wrote:
OS X 10.11.6 (El Capitan), EPICS R3.14.12, edm 1-12-102, HomeBrew openmotif-2.3.4.
Only changes to base are to configure/os/CONFIG_SITE.darwinCommon.darwinCommon to pick up homebrew rather than Fink or DarwinPorts:
OP_SYS_INCLUDES += -I/usr/local/include
OP_SYS_LDFLAGS +=  $(addprefix -L,$(dir $(firstword $(wildcard /usr/local/lib/*))))
<extensionsTop>/configure/os/CONFIG_SITE.darwinCommon.darwinCommon has
X11_LIB=/usr/X11R6/lib
X11_INC=/usr/X11R6/include
XPM_LIB=/usr/X11R6/lib
XPM_INC=/usr/X11R6/include
USR_INCLUDES += -I/opt/X11/include
MOTIF_LIB=/usr/local/lib
MOTIF_INC=/usr/local/include
no problems building, but attempting to run edm gives
Error: attempt to add non-widget child "dsm" to parent "edm" which supports only widgets
This weekend I’ll try removing and reinstalling XQuartz just to make sure that there are no dregs of my previous DarwinPorts installation of openmotif.
On Aug 25, 2016, at 6:45 PM, Jiro Fujita <[email protected]> wrote:
Well, the only thing I think I did was this:
In CONFIG_SITE.darwin-x86.darwin-x86,
# Homebrew OpenMotif
Then, I thought everything worked…   At least that’s my recollection.
Eric Norum
[email protected]
Re: OS X edm/medm openmotif woes J. Lewis Muir
OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes Jiro Fujita
Re: OS X edm/medm openmotif woes Eric Norum
Prev: Re: OS X edm/medm openmotif woes Eric Norum
Next: Control System Job Opening at PSI, Switzerland Rees Simon (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: OS X edm/medm openmotif woes J. Lewis Muir
ANJ, 14 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
