1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: 回复: Re: question about pcaspy
To: "Wang Xiaoqiang" <[email protected]>, tech-talk <[email protected]>
Date: Mon, 29 Aug 2016 20:22:01 +0800
hi, xiaoqiang:
Thanks a lot for your letter. In fact, pcaspy is very convinent and helpful for me, thanks for your work.
I have another question, can scan field be set to a arbitrary value such as 0.001? If it can work, corresponding, the server.process(0.01) will be set instead of server.process(0.1)?
Best wishes
Geyang 2016-08-29
发件人: Wang Xiaoqiang
发送时间: 2016-08-29 15:34
收件人: geyang; tech-talk
主题: Re: question about pcaspy
According to
http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#Configurin2,
you can set EPICS_CAS_SERVER_PORT
# on the server side
$ export EPICS_CAS_SERVER_PORT=5078
$ python dummy.py
# on the client side
$ export EPICS_CA_SERVER_PORT=5078
$ caget MTEST:RAND
MTEST:RAND 0.000 (SEVR:INVALID STAT:UDF)
But if the same driver is instantiated for many devices, you can create
the database with different prefixes.
if __name__ == '__main__':
     prefix = sys.argv[1]
     server.createPV(prefix, pvdb)
Then to run the server for each device
$ python dummy MTEST1:
$ python dummy MTEST2:
Best
Xiaoqiang
On 08/28/2016 02:45 AM, geyang wrote:
> hi,
>    I would like to ask if  SimpleServer's port can be changed to others
> in code, such as 5066/5068? For example, I have a device driver written
> by pcaspy, I want to implement the same driver for many same type
> devices on one machine, then I need to set them different server ports.
>    thanks a lot for your help.
> Best wishes
> Geyang 2016/8/28
Re: 回复: Re: question about pcaspy Wang Xiaoqiang
question about pcaspy geyang
Prev: Epics for Phoenix Contact ILC 150 ETH New User
Next: Re: question about pcaspy Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: question about pcaspy Wang Xiaoqiang
Next: Re: 回复: Re: question about pcaspy Wang Xiaoqiang
ANJ, 29 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
