1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: question about pcaspy
To: geyang <[email protected]>, tech-talk <[email protected]>
Date: Mon, 29 Aug 2016 09:34:53 +0200
According to http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#Configurin2, you can set EPICS_CAS_SERVER_PORT
# on the server side
$ export EPICS_CAS_SERVER_PORT=5078
$ python dummy.py
# on the client side
$ export EPICS_CA_SERVER_PORT=5078
$ caget MTEST:RAND
MTEST:RAND 0.000 (SEVR:INVALID STAT:UDF)
But if the same driver is instantiated for many devices, you can create the database with different prefixes.
if __name__ == '__main__':
    prefix = sys.argv[1]
    server.createPV(prefix, pvdb)
Then to run the server for each device
$ python dummy MTEST1:
$ python dummy MTEST2:
Best
Xiaoqiang
On 08/28/2016 02:45 AM, geyang wrote:
hi,
   I would like to ask if  SimpleServer's port can be changed to others
in code, such as 5066/5068? For example, I have a device driver written
by pcaspy, I want to implement the same driver for many same type
devices on one machine, then I need to set them different server ports.
   thanks a lot for your help.
Best wishes
Geyang 2016/8/28
回复: Re: question about pcaspy Silver
question about pcaspy geyang
Prev: RE: A problem while execute MEDM3_1_9 Mark Rivers
Next: Epics for Phoenix Contact ILC 150 ETH New User
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: question about pcaspy geyang
Next: 回复: Re: question about pcaspy Silver
ANJ, 29 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
