1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Autosave ignores PVs starting with some characters
Cc: [email protected]
Date: Thu, 8 Sep 2016 11:45:31 -0500
On 09/07, Andrew Johnson wrote:
> On 09/07/2016 03:02 PM, Mooney, Tim M. wrote:
> > Turns out EPICS won't load a record whose name starts with '.'
> The IOC does reject attempts to create a record whose name has any of
> the characters space, double-quote, single-quote, dot or dollar sign in
> it anywhere, not just at the beginning of the name. That is the only
> enforced naming limitation at the moment.
Hi, Andrew!
It would be great if the Application Developer's Guide could be updated
to state this.  In section 6.3.2 of the 3.14.12.5 version of the
Application Developer's Guide ([1]) it says:
  6.3.2 Unquoted Strings
  In the summary section, some values are shown as quoted strings and
  some unquoted. The actual rule is that any string consisting of only
  the following characters does not have to be quoted unless it contains
  one of the above keywords:
  a-z A-Z 0-9 _ - : . [ ] < > ;
  These are also the legal characters for process variable names. Thus
  in many cases quotes are not needed.
As you can see, dot is clearly in the character list, and the sentence
right below it says those characters are the legal characters for PV
names.
Lewis
[1] http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node7.html#SECTION00730000000000000000
Re: Autosave ignores PVs starting with some characters Ralph Lange
Autosave ignores PVs starting with some characters Konrad, Martin
RE: Autosave ignores PVs starting with some characters Mooney, Tim M.
Re: Autosave ignores PVs starting with some characters Andrew Johnson
Prev: motor command in synApp when invoking the drive file l123173
Next: Re: Autosave ignores PVs starting with some characters Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Autosave ignores PVs starting with some characters Andrew Johnson
ANJ, 08 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
