1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Question about ASYN setting Input & Output EOS
To: Michael Westfall <[email protected]>, "[email protected] Talk" <[email protected]>
Date: Wed, 12 Oct 2016 13:43:47 +0000
Hi Mike,
The problem is this line:
drvAsynIPPortConfigure("CFHT", "128.171.83.145:8912<http://128.171.83.145:8912> HTTP", 10, 0, 1)
The last argument to drvAsynIPPortConfigure is noProcessEos, and you have set it to 1.  That means you have disabled EOS processing.  You need to set that last argument to 0, not 1.
From: [email protected] [[email protected]] on behalf of Michael Westfall [[email protected]]
Sent: Wednesday, October 12, 2016 8:34 AM
To: [email protected] Talk
Subject: Question about ASYN setting Input & Output EOS
Setting the input and output EOS fails for me.
A portion of my startup script:
asynOctetSetInputEos("CFHT",0,"\n")
Set EOS failed: CFHT setInputEos not implemented
asynOctetSetOutputEos("CFHT",0,"\n")
Set EOS failed: CFHT setOutputEos not implemented
What might be the problem? Did we not compile something into the ASYN module?
Mike Westfall
Control Systems Software Engineer
[http://www.gemini.edu/images/GeminiLogo_4.5in_newSmall.png]
Re: Question about ASYN setting Input & Output EOS Michael Westfall
Prev: Question about ASYN setting Input & Output EOS Michael Westfall
Next: Re: Question about ASYN setting Input & Output EOS Michael Westfall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 12 Oct 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
