1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about ASYN setting Input & Output EOS
Cc: "[email protected] Talk" <[email protected]>
Date: Wed, 12 Oct 2016 10:48:56 -0300
Ah, thanks.
I forget why I put that in there, but that was the problem.
On Wed, Oct 12, 2016 at 10:43 AM, Mark Rivers <[email protected]> wrote:
Hi Mike,
The problem is this line:
drvAsynIPPortConfigure("CFHT", "128.171.83.145:8912<http://128.171.83.145:8912> HTTP", 10, 0, 1)
The last argument to drvAsynIPPortConfigure is noProcessEos, and you have set it to 1.  That means you have disabled EOS processing.  You need to set that last argument to 0, not 1.
From: [email protected] [[email protected]] on behalf of Michael Westfall [[email protected]]
Sent: Wednesday, October 12, 2016 8:34 AM
To: [email protected] Talk
Subject: Question about ASYN setting Input & Output EOS
Setting the input and output EOS fails for me.
A portion of my startup script:
asynOctetSetInputEos("CFHT",0,"\n")
Set EOS failed: CFHT setInputEos not implemented
asynOctetSetOutputEos("CFHT",0,"\n")
Set EOS failed: CFHT setOutputEos not implemented
What might be the problem? Did we not compile something into the ASYN module?
Mike Westfall
Control Systems Software Engineer
[http://www.gemini.edu/images/GeminiLogo_4.5in_newSmall.png]
Mike Westfall
Question about ASYN setting Input & Output EOS Michael Westfall
RE: Question about ASYN setting Input & Output EOS Mark Rivers
Prev: RE: Question about ASYN setting Input & Output EOS Mark Rivers
Next: Re: Measurement Computing Linux C Drivers & MHz TTL counter Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 12 Oct 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
